Home > Tdi > Defender 2.5na
Andyred90
Defender 2.5na
Looking to buy an old farm hack which is running a standard 2.5na which is pretty smokey.
is it better to retro fit a 200 tai or 300.
Andy
Post #338366 15th Jun 2014 11:00pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
If you fit a 200tdi, it will be easier, as the engine mounts for the NA are in the correct place for a 200.
The 300 you will need to weld new mounts onto the chassis. 1998 110 300Tdi White Hard Top
Post #338367 15th Jun 2014 11:07pm
shaggydog
200Tdi is much easer to drop in as the engine mounts are the same and it just mates straight up to the gearbox. There are lots of conversions out there, most notable is Steve Parker.
300Tdi is much more difficult as you have to change the engine mounts on the chassis.
Post #338370 15th Jun 2014 11:12pm
jst
200 is easier if you have a def engine, still easier to do with a disco lump, see threads here i did a while ago
http://forums.lr4x4.com/index.php?showtopic=2394
all you need to know to do it ^^^^ but you may need to register. i am same user name on there.
http://forums.lr4x4.com/index.php?showtopic=18285
think about exhaust outlet and air inlet setups.
with availability you may want to go 300tdi. disco and def lumps are the same, its a good lump, just means new chassis mounts to weld on. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #338417 16th Jun 2014 9:49am
