![]() | Home > Maintenance & Modifications > Question |
Will an 8 x 16 modular with a 285 on it, fit the rear door.
![]() 110 HCPU Tipper |
Morning Willy,
I think if you wind the studs out it will! Ever thought if one of those swing away carriers? You can get a lorry wheel to fit on one of those, Fekete's done it! ![]() Treat every day as if it is your last....one day you will be right!! |
Yep I'll get one eventually, just won't have time or funds before I go on the rally. Original Member Pie n Pea Club.
110 HCPU Tipper |
Winding the studs out or a spacer would be the only short term solution! Karlos may be able to enlighten you further as I don't know how much spare thread there is to wind out on! I've still got a standard Boost on the rear at the moment! I myself would be interested to know as well for sure! If you go through life with your head in the sand....all people will see is an ar5e!!
Cheers Fek, thought that might be the case
