Home > Technical > Drop Down Tailgate seal |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Our TD5 DCPU did not have any seals or buffers on it's drop down tailgate when we bought it. I have since fitted the buffers so it closes correctly and doesnt rattle.
I have also bought a new lower seal which has three holes punched in it for mounting, the parts diagram shows rivets should hold it on but there is no evidence of holes in our tailgate for rivets or screws. Therefore i am not sure to which surface or which direction the seal should be fitted. Would someone mind taking a few pictures of the seal on their own tailgate please? I also need the seals for the sides of the tailgate, these seem a little pricey at £12 each, I take it that it is the same profile as the normal door seal as fitted to hard tops, therefore I can just cut down a hard top seal? Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
9th Jun 2014 12:34pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5786 |
Click image to enlarge Click image to enlarge Click image to enlarge |
10th Jun 2014 8:32am |
Thanks both,
Although im not sure if that bottom seal is the same as the one I have, I was thinking it fitted onto the tailgate itself not the body! That is sort of what it looks like on the parts diagram: http://www.allbrit.de/UNI.cfm?PAGE=765022&SPRACHE=EN I will have another look this evening about fitting to the tub instead Cheers 02' 110 TD5 Double Cab Rebuild Thread |
10th Jun 2014 9:38am |
