Home > Tdi > Will a 2.5TD exhaust restrict a defender 200TDI
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Ok i think i have stumbled on something but thought i would ask first Embarassed Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #337017 9th Jun 2014 9:11pm
shaggydog
Shouldn't do, from memory they are same diameter only thing different is flanges.
Post #337052 9th Jun 2014 9:59pm
Caterham
I don't know but would assume not as it's intended for a more powerful engine ie greater gas flow?
Post #337053 9th Jun 2014 9:59pm
jst
i have fitted three tdi to 2.5TD exhaust systems over time, all worked no problem. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #337061 9th Jun 2014 10:16pm
shaggydog
Well as yours would have been a TD originally I would assume that you still have a TD exhust with a converter pipe down from the engine to the old system.
If yours is a defender 200tdi engine then I would just replace the exhaust system with a 200tdi system and move any brackets that need moving.
Whats wrong with your existing system is it rotten?
Post #337063 9th Jun 2014 10:16pm
cornish rattler
No the exhaust is nearly new but we have just bought a straight through middle pipe but the flanges are different aswell as the bore of the exhaust is a lot smaller than the new straight through pipe we have just bought so thinking of buying a new complete 200tdi exhaust but using the rear silencer just for the flange so we can fit some flexi pipe to but could quite end up buying a used rear silencer to do this depending on price and availability Smile Graham
Post #337096 9th Jun 2014 11:32pm
K9F
Are there no specialist exhaust places or engineering contacts you may have that could just 'rework' the existing flanges for you? Be quicker and less hassle I would imagine? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #337121 10th Jun 2014 8:28am
cornish rattler
Its ok we will get a new 200tdi exhaust and sell the old but nearly new 2.5td exhaust Smile Graham
Post #337378 11th Jun 2014 12:03am
Mdm
Can be made to work but not ideal due to size difference
Post #337613 11th Jun 2014 10:55pm
cornish rattler
Son fitted the new front pipe and straight through pipe yesterday but need to sort out the tail pipe still but we have found an exhaust place that will make us a solid but bent to shape tail pipe fit it inc any brackets needed and all we need to do is cut the hole in the rear wing so hopefully it will get done next week.
had it out just to see how it is with the new exhaust on and its quick but a little noisy due to not having a tail pipe fitted and the turbo lag has virtually gone Smile Graham
Post #337852 13th Jun 2014 12:58am
