Home > Maintenance & Modifications > What to soundproof with leftovers.....
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Ok. I've done some soundproofing on my double cab and have some 3 sheets of dynamat extreme left.
Looking for an opinion on what will give me the greatest benefit to sound proof:
1) Roof
2) Bonnet
3) front doors (unless I have to remove plastic lining stuff!)
All floors, foot wells and seat box and rear bulkhead done.
Thanks in advance.
Rob
Post #336871 9th Jun 2014 1:11pm
Killer90
Site Sponsor
if it was me i would do 1 sheet on the bonnet insert pieces, then 1 sheet per front door Thumbs Up
or buy another box and do everything Twisted Evil Twisted Evil
Edit: just saw its a td5, youll need two sheets to do the bonnet inserts, then split one sheet in half and do the bottom halves of the doors Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #336914 9th Jun 2014 2:53pm
Doors, then buy the rest off of everyone's favourite Essex boy. Rolling with laughter
Post #336930 9th Jun 2014 3:42pm
DC101
Thanks. Maybe I should buy a bit more ... But trying to save the pennies for the next big mod...
I will go for the bonnet first: do I need to cut templates for best fit and is the dynamat hood liner worthwhile, weighing up the cost/benefit and that I should be saving money!!
Post #336932 9th Jun 2014 4:00pm
You don't have to buy a pack, there is sheets you can buy. It's on E-bay.
I have two brand new rolls of tape (black) which I have had from late last year.
£15 for both if you wanted them, rrp about 20 ish.
Can't see me doing it this year.
Post #336935 9th Jun 2014 4:17pm
mk1collector
As the roof is the biggest flattest panel that is most likely to "drum" I would put all three up there
Post #336944 9th Jun 2014 5:29pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Surly the biggest improvement will come from doubling up on the transmission tunnel Idea
Post #336958 9th Jun 2014 6:18pm
mk1collector
As dynamat is a vibration damper it won't really make any difference doubling up on the tunnel unless it's very rattley
Post #336992 9th Jun 2014 7:44pm
DC101
Thanks for the replies.
I haven't been using tape with the dynamat, should I have been?
Also running 1.2 disco ratios which seems to have reduced transmission noise/whine.
Post #337012 9th Jun 2014 8:53pm
You should use the Dynamat tape to seal each piece ( the seams) and to keep everything in place.
After all if you don't do the seams it's not sealing it all properly.
Post #337054 9th Jun 2014 10:00pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
You could always cut what's left into lots of very small pieces of approx 10mm x 20mm and insert one into each ear, they'd last ages Rolling with laughter
Post #337062 9th Jun 2014 10:16pm
Diablo
1984 Defender 90 200 Tdi SW Keswick Green
I'd go for the roof.
As dynamat is a vibration damper, not a soundproofer per se, you only need to cover approx. 25% of a panel to massively reduce the resonation.
Post #337265 10th Jun 2014 6:28pm
g-mack
^^^ +1 dynamat isn't a sound absorb er or blocker, it deadens vibrating panels! My 109 thread
my youtube channel
Post #337280 10th Jun 2014 7:18pm
