![]() | Home > Off Topic > Stihl strimmers |
Boris Member Since: 02 May 2014 Location: Oswestry Posts: 21 ![]() ![]() ![]() |
When I was buying a strimmer , my local dealer advised getting the solid shaft as he said the flexible shafts can break quite easily
![]() I'll have a look after to see what model I've got ![]() |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1852 ![]() ![]() ![]() |
Sorry, I can't help on current models, my one Stihl brush cutter is a straight shaft (solid) and is approx 20 years old and still is perfect and the Stihl split shaft multi tool (strimmer, pole saw, hedge trimmer, rotary broom & cultivator) flexible shaft is 8 years old and perfect.......
Buy the biggest / most powerful you can afford in the Stihl range and you won't go far wrong. Keith |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2058 ![]() ![]() |
The less weight the better.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8222 ![]() ![]() ![]() |
the less complicated the more robust i have always gone on. Cheers
Andy80 Member Since: 31 May 2013 Location: Essex Posts: 492 ![]() ![]() ![]() |
Does Honda produce a suitable model as from experience there super reliable and 4 stroke effortless
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
We have several strimmers two are sitting broken in the shed, flexi shaft.
Just get the most expensive solid shaft one you can afford. We have some that are donkeys old. A lot of stihl stuff is now 4 mix so make sure you use the green two stroke mix. Also put a little extra than 50:1. Also look at husquarna because they offer a longer warrenty. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20761 ![]() ![]() |
Our Honda broke down too this year.
For the time bring just bought a cheap Ryobi but that doesn't seem to bad really in all honesty. The Honda was reliable but not the most powerful machine. I prefer the 2 cycles to be honest fuel mixing of not. If spending a lot in think we'd go Stihl this time not Honda. |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Go for a Makita. They do 4 stroke too, much quieter and less fuel useage.
Honda 4 stroke was gutless and only around for couple of years as so heavy to hold. I've had a Kawasaki one for over 10 years and its great. Use Stihl, Husqvarna and now Makita at work |
We've just got a new Stihl one on the farm, seems pretty good.
I'll have a look what model it is tomorrow. Replaced one that much have been about 20 years old that had had a *lot* of use. |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
I love the Stihl one that i bought a year ago and it works brilliantly. My father always buys their products and as far as i know never has issues with them.
