Home > Td5 > noisy fuel pump
dancerdave
United Kingdom 2000 Defender 90 Td5 Exclusive HT Santorini Black
noisy fuel pump
I had all the symptoms of a failed injector loom ( lumpy running, oil at the ecu, missing at high revs) and changed it yesterday for a new one and engine running much better. Very Happy
Then tonight while driving I started to hear a high pitched buzzing noise. Sad On checking, its coming from the fuel tank so do I need a new fuel pump? Is it about to expire? Is it just a coincidence I changed the loom yesterday.
The engines still running well.
Post #336296 6th Jun 2014 10:37pm
mk1collector
Could be sucking air in through the FPR or injector seals and washers
Post #336301 6th Jun 2014 11:08pm
If it is the puma, as you know it's submerged in the tank. Quite a few td5'ers have cut an access panel in the boot floor saves dropping the tank
Post #336309 7th Jun 2014 6:15am
dancerdave
I'm hoping it's injector seals as that would be much cheaper. Is there any guides to show how it's done?
Post #336338 7th Jun 2014 9:10am
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Unlikely to be injector seals IMHO - but they are easy enough to do if you need to.
I had this problem on a previous vehicle - I changed the fuel pump at considerable expense but the issue remained. I then changed the fuel filter and it was sorted. Lesson - change the cheap and easy stuff first, even if they are not the most probable cause! My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #336354 7th Jun 2014 10:34am
dancerdave
Apart from the noise am I going to cause any more damage by continuing to drive until I get it fixed. Engine seems to be running fine.
Post #336357 7th Jun 2014 10:52am
Laurie
It's perfectly OK to drive with a noisy pump.
Won't do any harm and is unlikely to breakdown.
If it is injector seals they will be prone to breakdowns.
Post #336358 7th Jun 2014 10:56am
dancerdave
Thanks. I'll try the injector seals and fuel filter first and let you know how I get on.
Post #336361 7th Jun 2014 11:00am
dancerdave
it was the fuel filter Laughing so cheap fix
Post #337816 12th Jun 2014 7:47pm
