Home > Wheels & Tyres > Feels a bit hard with pressures I have - advice? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20350 |
32front 38 rear for me but that is on a 90.
I don't tow either, not heavy towing anyway. I've ways ran this pressure as is in the handbook. I don't doubt a 110 may be a touch more though. |
6th Jun 2014 12:31pm |
When running at max weight or towing I use 30 psi on the front and 65 psi on the rear as per the book.
For normaul use I use 30 psi front and 38 in the rear. That's running 235/85/16 Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
6th Jun 2014 12:49pm |
235/85R16 For me too.
6th Jun 2014 1:01pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 520 |
Same tyres as you Pob and I am running 28/35 unladen / part laden. on max load and I mean max load when she is almost to the bump stops she is 28/48 on Std H/D suspension - works 100% fine, even wear and no odd handling
6th Jun 2014 6:50pm |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Thanks, looks like when I'm running round empty the pressures are a bit high making it a hard ride then
Will drop them and see 110 Hardtop |
7th Jun 2014 7:14am |
