![]() | Home > Maintenance & Modifications > Retrim Headlining - what I learnt |
rich Member Since: 08 Dec 2012 Location: automotive trim tech trim shop Posts: 264 ![]() ![]() ![]() |
for a first go and with a fabric with not much stretch to it i think you have done a cracking job
![]() well done looks good |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
As above, I think you did well.
r21 Member Since: 25 Apr 2014 Location: Merseyside Posts: 77 ![]() ![]() ![]() |
Cheers, its not bad but its not as good as I'd have liked....it cost £40 for the fabric, £13 for spray adhesive (although I only needed one and half cans and bought three) and £6 for new black fir trees, all from eBay
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Looks great, well done
![]() Steve |
Very good value.
![]() Might be interested in doing similar myself one day. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
Don't suppose you've got a link for the trim you used?
Need to get some for my G-W. |
I ordered the "thicker, dense fabric" which in hindsight might have been the wrong choice
http://www.ebay.co.uk/itm/321225777654?var...1439.l2649 The product I bought though was good quality its just not that easy (for me) to get into the curved shapes |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
What glue did you use? Also have you fitted this in the Land rover yet, I ask as i did the same with mine and it looked great however after a few days in the heat the fabric became unstuck from the headlining, so I am yet to re do it!!
http://www.ebay.co.uk/itm/161194046504?var...1439.l2649
Its supposed to be high temp adhesive, when using the hairdryer to mould the fabric it got very hot and didn't seem to affect the glue so hopefully be ok, I certainly don't want to redo it ![]() |
you will probably find that it will drop in some areas where its under a lot of tention.
i am yet to find a glue that will stay stuck to the original headlining material which is why i take it off to fix new material which can cause massive problems if you dont know how to take it off without destroying parts of the headlining |
If it all goes west Rich, I may have to seek professional help
Watching this thread well to learn some trimming tips!
The G-wagen roof lining is very similar to a defender; comes out in a few pieces, but is rougher than the LR one, so the glue might stick better. |
