Home > Maintenance & Modifications > Defender 90 suspension
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Hello
I'm thinking about renewing my Defender suspension this year. The current one is quite tired and sagging an inch to the right side.
First of all let me describe my car and it's use. It is a 1995 90 300tdi, with no anti-roll bars, and with 110 front springs fitted by the previous owner. I have a bullbar, a steel steering guard, a spare wheel carrier and plan to add a Browncurch roof rack. The objective of the roof rack is to be able to carry 4 people with their climbing/mountaineering equipment on the roof, or a rooftent in the future
The car is a daily driver, with weekend offroad use. I don't tow, but ocasionally carry some stuff in the back when doing some long trips. I also carry 4 people on the rear bench seats sometimes.
The original plan was to get some OEM Boge shocks paired with genuine LR springs and spring isolators.
It was recently sugested for me to get RRC "Police Spec" springs (NRC4304?) paired with spring isolators. I was told that they give a very small lift (1") and provide very good articulation.
- Are these police spec springs any good?
- Will they handle loads as well as the stock setup?
- Is the lift really that small? I'm not after a lifted suspension, can't see the point of them in a Defender.
- Can they be installed with the standard lenght OEM Boge shocks?
I know the genuine std or HD springs are a safe bet, but the really low price of the Police Spec springs is really, really tempting.
Thanks in advance for all the help
Post #296650 7th Jan 2014 7:18pm
geobloke
So you are looking for something to carry quite a bit of weight every now and again but the rest of the time the 90 will be mostly empty... Right?
All round HD springs may not be the answer. I have a 2002 110 which for many years I ran on the most HD springs I could get and understandably when mostly empty you felt every little imperfection in the road. The silver lining though was almost no body roll in the corners. The springs were Britpart +2" Lift; Front 230llbs Rear 420llbs.
This last 12 months I removed the HD springs and replaced them with Land Rover standard progressive springs (meaning the spring has 2 distinct spring rates), as found on TD5 and newer vehicles. The difference is brilliant, comfortable when unloaded and it will still carry 5 people plus gear when it needs to. In my 110 2002 case I fitted;
Front LH NRC8044 155/215llbs
Front RH NRC8045 155/215llbs
Rear RKB101111 270/420llbs
Your 300tdi 90 probably would have had the following when new;
Front LH NRC9446 175llbs
Front RH NRC9447 175llbs
Rear NRC9448 225llbs
The Police Spec rear springs you mention is a time old traditional way to lift up the rear end of a 90, originally spec'd for the Police Range Rovers, but as you can see they are in fact quite soft which is great for offroading in a 90 but not carrying weight;
Rear NRC4304 170llbs
Your other option is to put TD5 springs on your 90, I did this with my 1992 200tdi 90 and the ride was brilliant;
TD5 110 front;
Normal duty and progressive
Heavy Duty
Front LH NRC9449 225llbs
Front RH NRC9448 225llbs
TD5 Rear HD and Progressive
Rear LH NRC9463 (superceeded by RKB101240) 210/240llbs
Rear RH NRC9462 (superceeded by RKB101230) 210/240llbs
So if you want to have standard height LR springs then I would suggest a combination of the above.
If you want a little extra height but still want the above springs then you can use the spring isolators (ANR 2938), which apparently will give you about 1/2" lift or 1" if you use them top and bottom. There is also another version (RBC100111) which was for the Discovery front springs and includes a rubber spring locating cone as well.
For more spring information take a look at this site http://www.red90.ca/rovers/springinfo.html it is mostly up to date and very useful as it gives spring heights and rates for bearmach and old man emu as well.
Post #296809 8th Jan 2014 9:39am
Arierep
Thanks for the help.
There seems to be two versions of the 90 HD suspension.
One keeps the front 175lbs springs and gets the HD springs in the back.
The other puts the normal rear 90 springs (225lbs) in the front and the HD ones in the back.
Any comments on this?
Also, what is the word on Allmakes springs?
Are they any good?
Thanks
Post #297123 8th Jan 2014 11:59pm
geobloke
Hi Jose. No problem.
The first setup you mention with the 175llb on the front and HD on the rear was the setup used on the pre-TD5 90 truck cabs, AKA "The Farmer Special". The later TD5 vehicles came with the progressional springs, a one size fits all approach, on all the variants of the 90.
The second setup with the 225lbs springs on the front and the HD ones on the back were to accommodate a winch and bumper. Back when all winches used the much heavier steel rope so beefing up the front suspension was necessary.
The second setup might be what your vehicle would be best with considering the amount of gear and people you carry. However I would personally still prefer the TD5 setup with the progressional springs, at least that is my preference.
Nothing wrong with allmakes, good quality aftermarket parts. I use them a lot. As for the springs it is unlikely that they make them themselves, moreover they get the OE manufacturers for LR to make them to the same specs.
There are other manufacturers: Britpart, Old Man Emu, Pro Comp, Terrafirma, Bearmach to name some. All will work just fine, but the prices vary considerably.
Post #297184 9th Jan 2014 12:39pm
Arierep
Thanks again!
Still regarding the Police Spec NRC4304, does anybody knows why the high load rate of 1106lbs, as well as it's effect?
Thanks
Post #297283 9th Jan 2014 8:00pm
Arierep
I recently had the opportunity to drive a Defender with the NRC4304 Police Spec springs and really liked it.
Can those springs be mounted with the original lengh shocks?
Thanks
Post #335536 3rd Jun 2014 8:47pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Hi Jose,
I have a 1995 300TDi 90 pickup which I fitted 'Police Spec' RR springs to last year. The difference over standard was noticeable with a much more compliant ride on the road, much more composed. I fitted new standard dampers at the same time too and its worked well for me.
Having said that, I run it mostly empty with 2 up front max so don't really carry heavy loads in the back. If I did I suspect it might become too wallowy.
I'm very happy with the setup for my useage especially as it cost so little to do.
Andy
Post #335668 4th Jun 2014 11:57am
Arierep
Thank you,
How much lift did you got with those springs?
Post #335700 4th Jun 2014 2:56pm
L90Andy
Difficult to say - the springs and dampers I took off were old so wouldn't be comparing like for like. I have a winch with bumper on the front and nothing in the back so it is a bit front heavy.
Overall I guestimate circa +1in on the back and pretty much standard on the front. It sits nicely and doesn't look lifted.
Much more pleasant to use as an everyday car now and doesn't look 'modified'. Just what I wanted.
Cheers.
Post #335701 4th Jun 2014 3:00pm
Arierep
Thanks,
With the kind of offroad that I've been doing lately, I wouldn't mind a small 1" or 1,5" lift.
Besides the HRC4304 route, I am considering to move my standard rear springs (NRC9448/9) to the front and slapping a pair of HD RKB101230/40 on the back, coupled with a set of rubber spring isulators.
Post #335744 4th Jun 2014 6:05pm
L90Andy
I tried that first and found it still rode too hard, so changed the fronts too. I was chasing ride comfort though so slightly different from your requirements.
Off road it is a lot more comfortable and although articulation is actually the same (std dampers which limit travel) progress is smoother on technical sections.
Here is a picture of the ride height of mine:
[img]
[/img]
Post #335812 4th Jun 2014 8:48pm
roel
I have currently 225 lbs at the front and 325 lb at the back as I found the standard fronts to weak when charging up a hill. It bottomed out to easy at the start off the hill.
I use the 325 lbs at the back as I am building a rollcage at the moment. After that is finished I will have a look at the final spring setup as the weight is then known. Roel
2003 90 Td5 (2009-now)
Post #335892 5th Jun 2014 7:24am
takoon
Norway
L90Andy wrote:
Hi Jose,
Andy
Hi L90Andy
Did you considering standard RR springs before the police spec. I would like to soft`n the ride of my TD5 90 CSW and is wondering how the standard RR springs will affect the ride. I have a small Ramsey winch in front and no sparewheel at the rear and no anti roll bars
Robert -99 Td5 90 CSW
-09 Jaguar xk4,2 Portfolio
Post #337869 13th Jun 2014 7:59am
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Will change it today!
Post #337920 13th Jun 2014 1:15pm
Arierep
Well, I made my mind.
I'll go with the HD setup allround.
Why? I decided I'll install a winch in the near future, and two days ago I drove the car at maximum payload for the first time.
Lets just say the ride was awfull with the standard suspension setup...
Post #338034 13th Jun 2014 9:50pm
