Home > Technical > TD5 EGR |
Sorry Roel, but I don't know the answer to your question but from the following links it appears to be 'common practice' to blank the EGR AND plug up the vacuum pipe.
http://www.landyzone.co.uk/lz/f8/best-way-...74949.html http://www.lro.com/forum/viewtopic.php?t=3...f557a77b7e http://forum.landrovernet.com/showthread.p...king-plate If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
2nd Jun 2010 9:19pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Thanks K9F, I will do the proper job in the future but thought about a quick middle solution for the time being. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
2nd Jun 2010 9:32pm |
Roel,
I think the worse that would happen is that you will get an engine management light on....If it was as simple as blocking the pipe with a ball-bearing they wouldn't sell or have any need for the blanks I would have thought! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
2nd Jun 2010 9:38pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Disconnect the plug on the vacuum control valve on the right hand wing.
On pre 2002 there will be one control valve, post 2002 there will be two. Pete |
2nd Jun 2010 9:40pm |
I thought if you unplug the (for me 2) it could throw up faults in the ECU. I thought if you don't get vacuum on the control valves the ECU thinks they are still working but they don't. Roel
2nd Jun 2010 9:45pm |
Didnt throw and codes up for me (been checked on Nanocom many times since its been disconnected). And if it does they only come up once as far as i can tell. If they are disconnected the ECU knows they are not working and fuels accordingly. If you just blank it off the ECU thinks there working and fuels the engine for a working EGR when its not actually working.
On mine i have the EGR valve completely removed and the vacuum pipes removed and the control valves removed. Pete. |
2nd Jun 2010 9:54pm |
