![]() | Home > Technical > TD5 County 2001- diff lock light. |
Assuming it works on the start-up test, no light means the diff lock isn't engaged. First port of call should be the linkage on top of the box as they are known to seize up if not used every now and then. I can't remember how accessible it is just by removing the rubber boot. It may be necessary to take put the tunnel but, once exposed, a soaking with penetrating oil usually does the trick. Darren
Duffs Member Since: 19 Apr 2014 Location: Northumbria/ Cumbria/ Borders Posts: 48 ![]() ![]() |
I don't get a light on the dash on start up test either and from your reply, I take it I should. I will have a go with penetrating oil as first attempt. Thanks for the advice. 2001 DEF TD5 County
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6127 ![]() ![]() ![]() |
Td5 doesn't have a start-up difflock warning light. It's purely connected to the difflock lever.
Could be something as simple as the wire come off the switch (by Td5 age the plugs are decent waterproof ones, not spade terminals) Try jacking a front wheel up (engine off), and rotating said wheel... check it rotates OK. then engage the difflock lever, and try spinning the wheel again. If it locks up, you know that the difflock is OK and it's just the switch that's duff (or the warning light on the dash) |
Really? How quickly you forget...
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Will jack it up and see what's happening, thanks again.
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
I have had the very same problem a while ago. Cured by a douse with WD40. The linkage is accessible from underneath on the drivers side.
