![]() | Home > Technical > Svx lights -Relay not working with trailer dash indicator |
the dash light won't work with led flasher unit , you need the adjustable flasher unit , search Rdx flasher unit or Rdx relay on forum lots about it
Which make of LED lights and flasher unit did you use?
Some trailers/caravans have filament bulbs fitted, some have LED, therefore the resistance load/current draw can vary a lot. Talking to the technical guys who supplied the SVX lights to Land Rover he clearly stated that many of the aftermarket systems available would not function properly and legally with a trailer fitted. They supply what they call an Intelligent Power Loading Systems with their aftermarket LED systems. Maybe it is a case of asking your supplier for a solution? Brendan |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20629 ![]() ![]() |
The RDX relay will be your only option. I have one - does what it says on the tin.
Oscar Romeo Member Since: 16 Apr 2014 Location: South Yorks, the pinnacle of all human achievement Posts: 121 ![]() ![]() ![]() |
+ 1
![]() 5 min job! |
Myers Member Since: 07 Dec 2011 Location: Wiltshire / Sailisbury Plain Posts: 156 ![]() ![]() ![]() |
Yep, RDX relay will sort your problems. I have LEDs on the vehicle and have towed various trailers with normal lamps, works every time Myers - Somewhere on Salisbury Plain
Puma 90 Hardtop (XS Spec) |
