Home > Technical > Rear brake callipers
mk1collector
Does anyone know the difference between 90 and 110 rear callipers on td5s? According to brake pad suppliers 90s have the "bridge" type anti rattle shims but 110s don't. Can this type of anti rattle shim be used on a 110?
Ray
Post #335020 1st Jun 2014 4:58pm
110 rear discs are slightly thicker than 90 ones, So i suspect that the calipers are slightly wider too?
Post #335036 1st Jun 2014 5:31pm
bga86
2015 Defender 90 Puma 2.2 HT Fuji White
110 rear calipers have pins holding pads in the same as the fronts and 90's have the bridge type clips. Can't interchange them as they are totally different Thumbs Up
Post #335049 1st Jun 2014 5:58pm
mk1collector
Fair enough Thumbs Up cheers chaps
Post #335058 1st Jun 2014 6:23pm
