![]() | Home > For Sale & Wanted > [Wanted] Td5 Heater control mechanism control cable clamp. |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Should be available from main dealer I have bought them in the past, will have a look in my garage tomorrow to see if I have a spare.
Will pm you if I have one. 2005 Td5 90 XS Steve |
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 ![]() ![]() |
![]() I tried they will only sell me the whole unit! It's not the end clamp but the clamp that hold the plastic sheathed cable to the mount, hope I have explained that correctly ? Just to the upper right of the number 6. |
I was thinking you mean the clamp that holds the outer cable to the heater box under the bonnet, I have bought these but they came in a bag of 3 or 4 if I remember correctly. Is this not the part you are after ? 2005 Td5 90 XS
Steve |
No the other end in the cabin, the cable clamp into the heater control assembly
Just been out to have a look at mine and the clamp at the heater end is different. 2005 Td5 90 XS
Steve |
Thanks for trying its appreciated, will have to try and make something ! Unless someone else comes up trumps!
Cold probably use a clamp from the other end and drill a hole in it for the screw. 2005 Td5 90 XS
Steve |
