Home > Technical > What inverter or generator ?
looking at finishing the electrics on the trailer and I am going to fit an inverter or a small generator (Honda) ...
what inverter or generator do you use ? Looking for 1kw to 2kw ish ....
Post #332595 21st May 2014 6:40pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
we/ve got a honda EU20i which is brilliant and comes recommended
cc
Post #332613 21st May 2014 7:43pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Post #332616 21st May 2014 7:47pm
munch90
I got a eu20i , good little generator , but pricey
Post #332618 21st May 2014 7:51pm
martinfiattech
I have a lister ac 1 diesel 4 kw hand crank starter, very powerful you can run a welder and make tea at the same time Very Happy
For the nights a little Honda ex 650 purrs like a kitten Excuse the spelling I`am better with spanners and wires.
Post #332623 21st May 2014 8:14pm
Sonarmender
England 2015 Defender 90 Puma 2.2 HT Corris Grey
Honda EU201 any day of the week,
The only thing that comes close is the SDMO equivalent. (They use Yamaha Engines and actually build there suitcase generators for them) You only have one life, live it....forget the cost.
90XS Hardtop
Post #332672 21st May 2014 9:44pm
Thanks for the recommendations
I'll probably go for a Honda Thumbs Up
Post #332840 22nd May 2014 6:26pm
TJ101
Ditto,, Honda EU20,, You pays your money !!!! but still worth something come selling time,,
not a moments problem in 6+ years now, used yesterday up in Scotland, started first time as normal California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #333478 25th May 2014 3:53pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Lidl have 2800 watt generator on offer tomorrow for £179! You pays ya money Whistle 2005 Td5 90 XS
Steve
Post #333483 25th May 2014 4:04pm
gilarion
Depend what you are doing with the generator if you are going to use it on campsites etc. Then you need a quite one like an invertor Generator that is almost whisper quite, but they are pricey
If however you just want a generator to knock out a couple of kilowatts and are not bothered about noise then a cheap one of EBay or a cheap one from Machine Mart about £50.00 will do fine.
Just make sure you get one that is fuelled by unleaded petrol, the two stroke generators are a pain as you always find you have run out of two stroke oil when your need it the most
Post #333488 25th May 2014 4:11pm
K9F
Depends really what you intend using it for. A point to note perhaps is that the Honda EU20i will give less than 9 amps. Borderterrier's recommendation is a bit noisier, 30% more capability and ballpark £400 cheaper than the EU20i and still has Honda emblazoned on it.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #333519 25th May 2014 5:21pm
TJ101
Never had the need to use the 12v output on mine,, the 240v runs the water heater, battery charger, 20 plus low wattage lamps
First one i had was second-hand, bought for £500, and sold 3 years later for the same £500
borderterrier link may be £400 odd cheaper, but near 3 times the weight !! plus the ECM2800 in Non Inverter and a old discontinued model ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #333525 25th May 2014 5:43pm
K9F
Good point, well presented..... EU20i DC limit 12 Amps, AC 9 Amps. Would imagine for camping etc. it may be enough but with the way things are rumoured to be going with domestic power supplies if I were in the market for a generator I would be considering perhaps something a little more substantial so 'life could go on as normal' in the household should the need arise. But that's just me.
Post #333528 25th May 2014 5:55pm
Sonarmender
If you are going to run any type of computer equipment then you need a pure sine wave inverter type generator (Honda EU20i).
The Honda Generator will quit happily run any modern caravan and all its equipment with power to spare as it rated @1600 watts and gives a pure sine wave so your laptop and such items will be fine.
Try this link: http://www.justgenerators.co.uk You only have one life, live it....forget the cost.
90XS Hardtop
Post #333537 25th May 2014 6:27pm
Cupboard
Don't get one of these:
They're sold under lots of different brands but are all the same and rubbish.
I speak from experience.
Post #333554 25th May 2014 7:22pm
