Home > Technical > Puma Tdci - Which year to buy? |
just-a-drummer Member Since: 27 Aug 2008 Location: Athens Posts: 2 |
Hi everybody this is my first post!
After reading extensively the puma section of the forum this question came to mind: I want to buy a defender 2.4 tdci. Reading the various issues (tank breather, engine noise, etc.) and seeing that at least one has been fixed (breather relocation) is it safe to buy a 2007 build defender (with better price) or significant changes have been made to the 2008 build one's that are worth the extra $$$? Thanks for your feedback, Cheers from Greece |
27th Aug 2008 1:53pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
I think any age - atleast you know what to check for... Mike
27th Aug 2008 5:54pm |
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 |
I agree - it is luck. My 07 has been mechanically fine. The fuel tank breather relocation is a DIY and any dealer will replace the sump pan during a service if you ask nicely. So without much effort you can have an 08 spec. anyway. 2007 Defender 110
1970 Alfa Romeo 1750GTV |
27th Aug 2008 10:44pm |
Thank you so much for your replies. Still I cannot make up my mind whether i should spend 20% of the car's value to get a "fresh" landy.
I agree with the "luck" factor. Moreover I will know what to check for. But if you had the choice today what would you choose? After knowing what's up... |
28th Aug 2008 9:23am |
I chose what it wanted and what i could afford. If i could only afford/only wanted to afforf an 07 then thats what i would have got. Instead i could afford/wanted an 08 it just happened they had an already ordered 08 by the dealer (hence i had to have black and got all the extras) that was avaliable. You know what to look for (bearing in mind you will always hear the worst case here) so just get an 07 if you are comfortable there and check the known issues and spend the extra on toys for it. Mike |
28th Aug 2008 9:33am |
