Home > Technical > Diagnosis for brake issues |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
Vacuum pipes? Vacuum pump? Either could be failing. Probably a separate issue to the uneven disc wear, which at a guess is a sticking piston somewhere in the set up. It wasn't me!
21st May 2014 6:38pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
ive just discovered my servo is letting air in. i knew the breaks were not great so sprayed the servo with water and got it very wet then switched engine off with ear near servo. sure enough i could here it sucking air and water in! ordered new one will be here tomorrow! My 109 thread
my youtube channel |
21st May 2014 8:19pm |
Tom DCab Member Since: 13 Jun 2013 Location: West Sussex Posts: 33 |
I will give the water spray a try..might reveal a leak if it is on the outside of servo. I understand that the diaphram inside the servo can leak too..
22nd May 2014 7:59am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5700 |
Spray servo with wd40 and it will show the cracks.
Andy |
22nd May 2014 8:42am |
