Home > Off Topic > Diagnosis please - wheel bearing on an Audi
ZeDefender
I've never had a wheel bearing go (had them changed but never heard them) so I need some advice.
I have to drive about 1500 Km next week and the A2 has started making a low humming sound when steering left or driving straight on. Steering right makes it disappear. It's getting worse and you can feel it through the gas pedal at certain speeds. Steering hard left (not right) at some speed makes a light knocking sound.
The tyres only a couple of years old, look in good condition and are evenly worn.
Can I be (almost) 100% certain it's a front (right?) wheel bearing?
No Audi garage has time to do the work so I need to get the parts for our local one.
Cheers for any insight Bow down
Matt Tell someone you love them today because life is short.
Post #332222 20th May 2014 8:36am
K9F
Whatever you do to one side it is 'good practice' and the prudent thing to carry out on the other to prevent undue stresses on the older item. My advice would be to do BOTH fronts.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332224 20th May 2014 8:38am
ZeDefender
Cheers. So definitely bearings? Tell someone you love them today because life is short.
Post #332225 20th May 2014 8:41am
K9F
Sounds like it....have you jacked up the front end and rotated/spun the wheels and see if there's any lateral play in the wheels themselves?
It can be very difficult sometimes to detemine whether it is front or rear due to sound resonation through the vehicle. Jacking it and doing the above may give you a pointer. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #332229 20th May 2014 8:47am
ZeDefender
I checked about a month ago when I put the Summer wheels on but couldn't feel any difference between L and R (slight play in both - not sure what's normal). It's got a lot worse since then so I'll get off my backside and check again tonight Thumbs Up Tell someone you love them today because life is short.
Post #332248 20th May 2014 10:40am
landy andy
What you have described is classic wheel bearing symptoms. You can't always feel play. Sometimes the bearing race has become pitted and this generates the noise. Easiest thing to do is change both sets, otherwise you'll never be happy not knowing.
Andy
Post #332276 20th May 2014 12:54pm
ZeDefender
Thanks guys - car is booked in Thumbs Up Tell someone you love them today because life is short.
Post #332278 20th May 2014 12:59pm
ZeDefender
All done today - picked it up and an incredible difference, like a new car.
Only downside is they need a part to fix the ABS/TC tomorrow... and an A2 without TC in the rain is like a go-kart on a skid-pan Rolling Eyes Tell someone you love them today because life is short.
Post #333753 26th May 2014 4:28pm
