Home > Td5 > Prop shaft balance and correct bolts? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17373 |
Correct bolts are 3/8" UNF with Nyloc nuts (do not use setscrews), grade 8.8.
Propshaft balance cannot cause clutch slip. |
18th May 2014 9:41pm |
Duffs Member Since: 19 Apr 2014 Location: Northumbria/ Cumbria/ Borders Posts: 48 |
Thank you blackwolf for advice and spec, much appreciated. Thought the vibration 50-60mph up hill was props, but likely clutch now. Had a go at props because slip in .4 and 5th was not obvious before now. 2001 DEF TD5 County
18th May 2014 10:39pm |
If you can't track it down to anything else, you could try fitting a double-cardan prop (similar to a Disco2 but unfortunately a different length) at the front.
It is food for thought that on the D2 LR fitted a DC prop at the front to reduce the vibration cause by the transfer box output flange and the front diff input flange not being aligned. On the Puma, since the engine is raised at the front the misalignment is greater, but a standard prop is fitted. For some inexplicable reason some Pumas seem worse than others, but in some cases fitting a DC prop (which you can buy from Devon 4x4) will make a surprising difference. You can of course test (if you haven't already) by running with no front propshaft fitted and with the centre diff locked. If the vibration is gone, chances are it is the front prop misalignment issue. |
19th May 2014 7:44am |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
That isn't even a Nyloc on there! Wouldn't be surprised if it came off pretty quickly!
19th May 2014 1:03pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Can I advise that a very cheap thing to do is to properly adjust the handbrake to eliminate it before you look for more expensive fixes. |
19th May 2014 1:09pm |
Cheers chaps for the suggestions, it will keep me busy. I suppose it is a case trial and elimination. Least I can fit the correct bolts to start. 2001 DEF TD5 County
19th May 2014 4:40pm |
