Home > Puma (Tdci) > ScanGauge2 no response |
Generaldej Member Since: 30 Dec 2012 Location: Milbury Heath Posts: 82 |
Hi
I've just disconnected the EGR as the chucking noise is getting worrying. The vehicle is a 2009 CSW and had done approx 37,000 miles. I'm planning to remove the erg to give it a clean. I have looked at lots of threads and was considering changing the fuel, but I would have to drive well out of my way to fill up with shell or bp ultimate. However, I was under the impression that once the engine warning light comes on I would be able to distinguish it using my scangauge2. But, I get two fault codes, P1402 and p1409. I press the clear button, get a waiting message followed by no response. Has anybody else had this? Click image to enlarge I know the gauge is working as it displays rpm etc correctly. |
18th May 2014 5:45pm |
Cheers Josh, did exactly what you said and cleared the codes. MIL light extinguished when starting the engine.
18th May 2014 8:28pm |
