![]() | Home > Td5 > Red fluid |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
The leak is most probably ATF and will be coming from either the power steering box or one of the two pipes which run to it. They are clipped to the front chassis cross member. 2002 110 td5
timtom1 Member Since: 10 Jul 2012 Location: Lancashire Posts: 148 ![]() ![]() ![]() |
Thanks I will have a look in the morning and take a picture and post it on here. 2001 90 TD5 CSW Alveston Red Manual
I did upload some photos but can't find them in my gallery?? Will keep looking. Going underneath this morning looks like a pipe has split but not sure what its for. 2001 90 TD5 CSW Alveston Red Manual
![]() Click image to enlarge Is the above a split pipe? if so what does it feed I think that might be where the fluid is coming from ![]() Click image to enlarge ![]() Click image to enlarge 2001 90 TD5 CSW Alveston Red Manual |
in red box is starter sol coil wire to relay and so no
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Seems to be at the rear of the engine on drivers (RHD) side.
Brake fluid, Clutch fluid, coolant......one of these is red as shown in the photos in the expansion tank or is it a reflection of something else? |
ON my one it was the fuel presser reg
could be clutch fluid then? because clutch is sounding a hec of a lot creeking??
sol coil is damaged though in the photo is it not? yep the expansion tank is red 2001 90 TD5 CSW Alveston Red Manual |
![]() ![]() ![]() Last edited by dorsetsmith on 17th May 2014 10:26pm. Edited 1 time in total |
HansT Member Since: 25 Dec 2012 Location: Mariefred Posts: 173 ![]() ![]() ![]() |
I have a leak from the same area but as my Defender is LHD it can not be clutch or brake fluid. So I will check the coolant expansion tank soonest. Can you let us know what the workshop finds when they check it? On mine the fluid runs down on the cover under the engine and mixes with other fluids and grease and muck so it is difficult to identify type of fluid.
yes I will let you know, its going to the Garage on Monday afternoon 2001 90 TD5 CSW Alveston Red Manual
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
Tim, Just had a similar problem with mine stalling & taking a few goes to start. When I did get it started it seemed to chug into life then it was as if nothing had happened. It happened 3 times in 1day. Got it checked out with a diagnostic check first but nothing showed up. He then checked fuel pump & that was fine. Checked injectors & they seemed ok but with the guys experience he said it could be the seals going. Got him to change the seals & touch wood all seems good now. Apparently then can let air in which makes it hard to start & run a little rough. This is only my 2p worth. Hope you get it sorted. ![]() |
thanks Martin, I'm 90% sure its the coolant that's leaking but I will ask them to check the seals as not sure why it wouldn't start then started up.
Thanks again, I will let you all know what the outcome is ![]() |
Checked mine for leak today and it is not coolant. And not clutch or brake fluid as mine is LHD. I belive that it is engine oil coming from somewhere rear of the engine. Will have Another look tomorrow.
