Home > Puma (Tdci) > Turbo Hose Replaced |
Shorty53 Member Since: 17 May 2013 Location: Lancashire Posts: 135 |
My 2012 2.2 was recently at the dealers for 'routine' warranty work. They OFFERED to replace the turbo hose with a modified arrangement under warranty. This due to pulley abrasion risk. This was done today (3 hour wait in reception). Dealer said that if required turbo hoses will be replaced on 2.2's that pass through the workshop during warranty or service work.
14th May 2014 10:16pm |
It is a common fault and well documented on the forum. If you go through life with your head in the sand....all people will see is an ar5e!!
15th May 2014 7:00am |
Surrey Rover Member Since: 20 Dec 2010 Location: Surrey Posts: 360 |
Count yourself lucky you didn’t discover the fault at the roadside! http://www.defender2.net/forum/topic27681....rrey+rover Nick 2.2 110 Tipper |
15th May 2014 7:40am |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
The 'modified arrangement' I believe is just just a cable tie lifting it up out of the immediate danger zone!
15th May 2014 8:57am |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3784 |
Where is the "danger zone"?
Pickles. |
15th May 2014 9:14am |
Where the turbo hose passes the belts and pulleys for the Alternator etc ..
See Jim_bean's thread (He's on his 3rd or 4th hose I think now and this time, they cable tied it up to another hose to stop it bouncing onto the pulley/belts) ... http://www.defender2.net/forum/topic21673.html |
15th May 2014 9:23am |
stevie Member Since: 16 Sep 2008 Location: Nottinghamshire Posts: 246 |
The modified hose has a bracket to hold the pipe in a fixed position. I know as this is my 4th pipe and now it looks like it will last
20th May 2014 8:21pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
Mine was done as it was rubbing on the steering column. Nice new bracket and hose fitted.
21st May 2014 4:01pm |
