Home > Td5 > Defender TD5 Heisitating and loss of power |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2378 |
Hi
I have a Defender 110 TD5 2002 with 160k and a BAS Remap and full width intercooler. Symptoms are that when I start it sometimes, it seems to be hesitating and down on power for a little while until it suddenly wakes up and goes like it should. Today I drove it for the first time in a while and while on the way to ride my MTB at Cwmcarn, I decided to give it the full beans on the bypass and it went ok up to 70mph then suddenly Land rover said NO and cut power then and engine light came on. Pulled over and restarted it, engine light was off, and carried on, loss of power wouldn't go over 50 until a mile later when it woke up and went back to normal! So thoughts? 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
11th May 2014 10:42pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5568 |
Had this before. Was first time MAF failure. Gary @ alive does uprated ones that are the only ones that lasted on mine.
Andy |
12th May 2014 8:25am |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
99.9% knackered airflow meter, you're not far from me, let me know if you're having major probs and I'll stick the computermabobin on it for you
12th May 2014 10:14pm |
Ellis01 Member Since: 16 Nov 2012 Location: Durham Posts: 14 |
Does sound like MAF. Readings should show if it is. VDO/OE MAF should do it, some companies sell as uprated
14th May 2014 7:48pm |
Hi
My ECU plug has never worked so can't plug the thing in lol will order airflow meter and MAF 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
17th May 2014 8:06pm |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
I just had the same with mine, all the symptoms were leaning towards the MAF sensor, but the functioning part of my brain wasn't convinced. Slip a blanking plate in to block the EGR. This will give you an indication if it's MAF or EGR related.
It's cheap too! It wasn't me! |
18th May 2014 9:56am |
