Home > Technical > Clutch
MK
Clutch
Hi Guys
I have some news. I went to explore under the cubby box since I had a bit of a noise when shifting in 1st gear (I know what it was Evil or Very Mad ). Well, every time I do that I can see the hand brake drum rotating a bit. So the clutch I guess is not working as it should be. Anyway, I think it has been like this since the changed the clutch.
Do you think it is acceptable?
thanks
mk Puma 110" SW
Post #31442 4th May 2010 8:12pm
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Hi, MK!
Mine do the same, and I had my clutch replaced 10000 km ago (with 25000km), I think it's normal, but still don't ask my dealer about it, and it didn't do all times, so I think it's normal, waitng a little more time with clutch depressed may help, but not solve, and lets remenber that is a Defender, everything is possible!!!!
Post #32349 16th May 2010 10:31pm
MK
Hola
NFWay I´ll leave it as such. Puma 110" SW
Post #32351 17th May 2010 12:10am
MK
For those mechanically wised, what could be the issue with Defender`s weak clutch?
Plate Size?
springs?
pressure plate?
I know the 1st generation had problems with the springs, but I´m trying to find out why the 2nd type sometimes also fails.
cheers
MK Puma 110" SW
Post #32531 19th May 2010 11:47am
Cibit
1st service next week for me and some warranty work. I mentioned the clutch and I do believe they are going to replace it. Question is will it be 1st or 2nd generation on a 2010MY Question 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #33100 27th May 2010 12:51pm
MK
in this forum there is a pic of the 2nd type. Also ask for the part number they will use. Puma 110" SW
Post #33108 27th May 2010 1:47pm
