Home > Puma (Tdci) > Clunk, ping, boing... |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
clunk, ping, boing hey? www.ralton.co.za
26th May 2010 9:44am |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Sounds like a pop song... no, actually those are the sounds the 110 makes as you put it into gear and drive away.
26th May 2010 12:16pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Are you sure you drove a Defender? I get Bings and boing from my D3 but no Clunks. My Defender has Clunks. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
26th May 2010 6:59pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Maybe will be a good idea to have a "noises dictionary" to have a reference of how a bing, rattle-rattle, Clunk, Clonk, boing, put-put, clang, hiiii, rrrrr, cri-cri among others "noises" should sound. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
26th May 2010 7:19pm |
Picked up the truck yesterday, it is scheduled to come in again in a few weeks, as there is a bit of work to be done.
According to LR, there is some play in the pinion up front (?), and a clearance issue with the nearside half-shaft . They've also got to swap out the rear step, as it is rusting already and replace the isolator foam on the doors. The clutch pedal spring has also corroded (?!?!), and will be replaced. It squeaks like an angry mouse and drives me up the wall, so good that it is going. |
27th May 2010 7:09am |
at least it's all getting fixed.
you didn't mention the angry mouse sqeaking sound? how does that go? www.ralton.co.za |
27th May 2010 8:15am |
It goes squeakSQUEAKsqueakSQUEAKsqueak every time you so much as look at the clutch.
27th May 2010 8:19am |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Rusted clutch spring probably from break fluid from clutch master cylinder dripping onto same spring
28th May 2010 2:36pm |
Oh, that would be lovely.
28th May 2010 2:56pm |
