Home > Maintenance & Modifications > Post 2007 dash
What puddle?
Post 2007 dash
Has anyone on here fitted a post 2007 dash into a pre-2007 car? I mean all the bits, including heater and air conditioning too? Is it just a matter of buying all the LR parts and starting again.
Readers may note that this is NOT a Land Rover Media image, as it has the steering wheel on the correct side Now left.
Post #330141 11th May 2014 7:16am
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Think killers in the middle of doing one Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #330143 11th May 2014 7:22am
mk1collector
Wouldn't it be very hard to change gear?
Post #330204 11th May 2014 11:22am
Killer90
Site Sponsor
It's not easy Big Cry
Gearstick,fuse box and heater is the biggest problem everything else is ok Thumbs Up I'm lucky as the customers one I have in wanted a auto so that's what we have fitted Thumbs Up you would have to heat up and reshape the gearstick otherwise Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #330234 11th May 2014 2:18pm
Wangers
United Kingdom 1995 Defender 110 300 Tdi CSW Aintree Green
how mcuh for a convertion killer? Ball park as been tempted for a while and if you're doing one, you can always do a second.....
Post #330240 11th May 2014 2:41pm
Retroanaconda
There's also the issue of the gauges/instruments. Tdci uses CANBUS which no previous Defender has, so in order to use the later instruments you would have to add a CANBUS system via some sort of controller that could read the parameters and feed them to the gauges. The easier option is to remove the later gauges and put a set of Td5 ones in their place, this is what I would do.
Gearstick could be solved by bending it as above or maybe by changing for a Discovery gearbox which I think might put the levers further back (ie. halfway into the seatbox). You'd have to do a bit of cutting about.
Post #330336 11th May 2014 6:40pm
What puddle?
Retro, very informative, thanks. Think I might give that idea a miss then. Now left.
Post #330377 11th May 2014 8:09pm
Killer90
Site Sponsor
IMO best off with a td5 late dash fits lovely and works perfectly Thumbs Up
Rough figure is about £1500 matey Thumbs Up CSK Automotive
Post #330386 11th May 2014 8:22pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
I have thought about doing the opposite and fitting a td5 dash with vents in a new tdci but thought I would just get a td5
Post #330396 11th May 2014 8:36pm
