Home > Wheels & Tyres > Steel wheel refurb advice
Paullr90
United Kingdom 2003 Defender 90 Td5 XS CSW Bonatti Grey
Evening all.
I've decided to treat my rims on the Series to a refurb as I need to get a new set of tyres fitted. Question is should I just brush paint them limestone again or should I powdercoat them? I want to do a proper job as I'm slowly doing a rolling restoration on the old girl.
Paul. 2003 Td5 90XS
1970 Series 11A 2.25TD
2013 Freelander 2 HSE Lux (the wife's)
Post #330385 11th May 2014 9:20pm
jimbob7
A proper job would be powder coat. Pov.spec,ftw. 2006, 110,TD5.
Post #330401 11th May 2014 10:01pm
Paullr90
Is it expensive to get a special colour like Limestone white? All the places round me are used to JCB yellow or black!
Paul. 2003 Td5 90XS
Post #330410 11th May 2014 10:14pm
Beg to differ. A proper job on a classic would be wet blast (or grit blast), acid wash, prime and paint. Then you'll have wheels which will look as they did when they left the factory but will stay looking that way indefinitely.
Powder coat is too modern and often disappointing for durability.
Post #330411 11th May 2014 10:16pm
Cuthbert
Powder coating can often chip easily - especially if your local tyre fitter is a 16 year old who was flipping burgers for a career last week.
Just like painting - unless the prep is done 100% and the QA is thorough - powder coating can deteriorate rather quickly.
Post #330540 12th May 2014 3:31pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Hi,
Did a home refurb on a set of wolf rims a month or so ago- as has been said its all in the prep, but also the paint makes a big difference too!
On ours we did the following
Wire brushed off all the loose flaky paint
Emery cloth completely by hand
Paint any bare metal with rust treatment
Masked very very carefully, using a butter knife to force the tape into edge of the rim
Degrease/wipe off any dust/muck
Two coats of primer-rattlecan
Two coats of topcoat- brushed
Its all about the prep and getting a decent couple of coats of primer on too then a good quality topcoat. I used hycote primer and chawton white from the paintman and the finish is superb.- there are a couple of little runs that only me and my partner see- nobody else would notice unless they were specifically looking for them.
Having tried to do the spare with a generic metal paint and the finish was awful I would plump for decent paint every time.
It takes quite a bit of time (we did ours over the course of about a week) and is a massive faff but the finish was worth it in the end. All in i think it was bout £50 of materials if you include a couple of good quality brushes masking tape etc.
Chris
(p.s you can also then make a reasonable job of touching any scrapes/marks you pick up- one of ours has already had a minor altercation with a large rock)
Post #354945 1st Sep 2014 4:14pm
K9F
I'm with Jimbob on this. I don't know how long people expect powdercoating to last on wheels that are by nature in the harshest conditions? If done correctly it's certainly more resilient than standard paint. I've had a set of steel powdercoated wheels on my Defender for over four and a half years when they were initially fitted and they've never been off. Realistically they are only just beginning to show signs of deterioration and that is predominantly around the area the weights were fitted.
I recently purchased a second set from Matt at FCX. They had been well-used with some deep scoring on the inner rim paintwork. Trip to the powdercoaters for stripping, washing and recoating. Dependant on where you go expect to pay £30-£40 per wheel for this service. If you wish for an 'usual' colour that they don't stock, expect to pay more. The RAL (or from whatever colour chart you decide) amount of raw material they will have to buy will coat a damn sight more than 5 wheels and if nobody else wants it it is a waste, pick a colour they have in stock would be my advice. The coaters I used had loads of choices.
From.....
To.....
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #354948 1st Sep 2014 4:44pm
kipperthedog
http://craftmaster.myshopify.com/collections/land-rover-colours
Limestone is listed in the 70's range.
Excellent quality paint, use their primer and undercoat for best results
Post #355605 4th Sep 2014 2:59pm
munch90
if blasting standard series rims , one thing to watch is if you have them metal grit blasted is that the metal chippings get wedged down in the joint where the inner part of wheel joins the outer rim , and start rusting very quickly , if you have them done by a proper wheel refurb company they may dip them which is better
Post #355616 4th Sep 2014 4:02pm
