Home > In Car Electronics > Replacing standard LR radio/CD player with an Alpine stereo
Page 2 of 2 <12
Tonyrec
Never thought about that. If I had purchased a similar HU from say Halfords, it would have the correct connectors fitted?
Post #330304 11th May 2014 5:11pm
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
I have been following this thread with interest.
Can anyone recommend an aftermarket single DIN DAB radio with Bluetooth/MP3/USB/AUX capability that could just slot in to replace the 2013 XS radio/CD?
Ideally, I can then just extract the LR one and plug in the replacement since I don't do electrics Embarassed
At the moment, I am using DAB via the AUX cable so I don't get the benefit of the subwoofer. 1970 Series 2A 88"
Post #330305 11th May 2014 5:14pm
Tony - Yep, a single female ISO plug. Thumbs Up
Most people have the opposite issue if the have a new Defender, they find the have the female LR plug present (which you HU is designed to fit)
And they want to fit a HU with ISO plug on it, so then they need the adaptor.
Of course, I guess you could always sell your new HU and get another aftermarket one.
A Kenwood would fit nicely, straight in, easy as pie. Whistle Wink
Post #330306 11th May 2014 5:14pm
Luke - First you want to check to see what loom you have, ISO or LR specific. I think post 2012 is specific and non ISO but do check.
If ISO then any aftermarket HU will slot straight in, if specific just get the adaptor and bobs your uncle slots in again.
Determine if you need a single DIN radio cage too for security's sake and to keep it secure or it'll move about if not slide out! Shocked
Post #330308 11th May 2014 5:18pm
lukev01
Thanks, Steve.
I will find out in a couple of weeks when it is booked in to sort out the condensation inside the indicators/sidelights at the front. 1970 Series 2A 88"
Post #330311 11th May 2014 5:27pm
Tonyrec
Cheers Steve.
I may have found a ready made lead on Ebay. It is item number eBay Item No. 251321637967
What do you think?
Post #330318 11th May 2014 5:40pm
Could well work, if not you could always return anyway. Thumbs Up Try it, might be the easiest option if it works okay.
Post #330320 11th May 2014 5:47pm
For reference:
Post #330435 11th May 2014 11:07pm
Tonyrec
Cheers Steve Bow down
Post #330469 12th May 2014 7:08am
Tonyrec
Update
The lead that I bought from Ebay worked a treat. Stereo is all fitted and working as it should. Mr. Green
Cheers Steve for all your input Bow down
Hopefully this thread will assist others who find themselves in a similar position.
Post #330879 13th May 2014 9:09pm
Brill, that saved you doing any hard wiring then. Thumbs Up
Post #330900 13th May 2014 9:57pm
Page 2 of 2 <12
