Home > Puma (Tdci) > problem with Horn |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 |
Has anyone had problem with the Horn?
I have only one 'tone' on the horn when normally it should be '2 tone'. Suddenly developed! Any suggestions? Joe 'El pepe flamenco' JLS 'El Pepe Flamenco' |
25th May 2010 8:24am |
there are 2 "bell" one on the left headlamp and one on the left (you can see the little grill under the position light).
check the "bell" that doesn't work and check the wiring loom, connector...... removing the headlamp.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
25th May 2010 8:34am |
Thanks, dgardel - will examine this today.
Regards Joe 'El Pepe Flamenco' JLS 'El Pepe Flamenco' |
25th May 2010 12:19pm |
No Luck!
Have checked the Horn on the left (LHD vehicle) - no sound coming out. I think it may be the Horn itself or the wiring, although the connector and earth seem OK. Joe JLS 'El Pepe Flamenco' |
26th May 2010 7:11am |
Don't want to teach anyone to 'suck eggs'......Swap the two horns over....easiest way to determine whether it's wiring or the horn itself. If you go through life with your head in the sand....all people will see is an ar5e!!
26th May 2010 8:06am |
Or put a 5W 12V bulb on the connector (car side) and try to "beeeep"................. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
26th May 2010 12:28pm |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Or a voltimeter to be more pro.... Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
26th May 2010 12:33pm |
Or your tongue, dick, finger or any other appendage you can get to fit, however in these instances you will of course need a second person to go 'beep flippin' beep!' If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
26th May 2010 12:46pm |
Regarding the 2nd sentence It is only a matter of how long your appendages are Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
26th May 2010 2:24pm |
xatzhs Member Since: 12 Dec 2010 Location: Northumberland & Down South Posts: 258 |
jlerra did you have any luck with this? I seem to have the same problem but haven't worked out which side it's not coming out of.
15th Sep 2011 4:27pm |
Hi,
Yes I fixed it - it was the 'high' tone horn, identified by exchanging the working horn for the suspect one. Bought one and replaced and fine again. jlerra El pepe flamenco JLS 'El Pepe Flamenco' |
15th Sep 2011 4:37pm |
