Home > Puma (Tdci) > Gear Selector Rattle
mse
Does anyone have the GTR reference on them.
Despite having one done in the past (then the old dealer breaking the fixed one) they are denying there is even a fault with it...using the "charactoristic of the vehicle" crbollapocks! Mike
Post #32862 24th May 2010 7:02pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Likewise, having the same problem too. Dealer has agreed to replace transfer box but i doubt that is going to rectify the problem. Anyone please shed some light on this issue?
Cheers Whistle '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #32954 25th May 2010 9:40pm
mse
Im glad its not just me...although its more annoying when you have had one replaced by a different dealer stating "it shouldnt do that...its the selector guide, we will order one" and bang - fixed never to do it again! (until a new selector was fitted) only for the new dealer to state there isnt a problem with it... Evil or Very Mad Mike
Post #32958 25th May 2010 10:10pm
sasha2001
Russia 2008 Defender 110 Puma 2.4 CSW Tonga Green
is this it?
Technical Service Bulletin No.LTB00211
30 April 2009
Subject/Concern: Transmission Stuck in Gear, Selector Shaft Detents Now Available
Models: Defender (LD) 2.4 Puma Diesel 2.4 Puma Diesel VIN-range: 7A732615 Onwards
Markets: All
Section: 308-03
Summary: This Technical Bulletin is to advise that the transmission selector shaft detents are now available as a serviceable part. Therefore it is no longer necessary to replace the complete transmission assembly for concerns related to the transmission selector shaft detents (transmission stuck in gear).
Should it become necessary to replace the transmission selector shaft detents, refer to the new procedure detailed in Global Technical Reference GTR Workshop Manual, section 308-03.
Parts Required:
Description Part Number Quantity
Transmission Detent Kit LR017294 1
Labour Time:
Operation Description Operation No. Time
Selector Shaft Detents – renew 37.16.75 4.9 hours
Post #32974 26th May 2010 9:04am
mse
I dont think so, but you have reminded me of the occasional trouble selecting first/2nd. Mike
Post #32978 26th May 2010 9:15am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
I've had my selector plate replaced due to a rattle. The new one is better but not rattle free.
It's worse when under a bit of strain (going up hill in 6th, etc).
I have come to believe that it is actually normal for it to rattle a bit. The owners manual warns you not to hold the gear lever while driving - if the selector plate resulted in a tight fitting lever, that would amount to the same as holding the gear lever with your hand.
I've also convinced myself that i'll get better mileage out of the box if i allow a small amount of rattle.
AND, if it does get too bad (after the warranty expires) it won't be tooooo expensive to replace.
Just my few cents worth...
Cheers www.ralton.co.za
Post #32990 26th May 2010 10:42am
MK
I got a sort of high pitch-metallic clinking noise coming from the bellhouse-gearbox area. I think it is somehow related to the selector and I get also the noise when I shift between gears and engine is off. Could it be the gear selector? Puma 110" SW
Post #40165 8th Sep 2010 1:23pm
