Home > Puma (Tdci) > Brake fluid plastic bottle cracked.
Pickles
Just had a look under the bonnet of our '13 Puma today, & noticed a bit of weepage around the brake fluid container.Closer viweing revealed that the container was actually cracked. Obviously I'll have it replaced under warranty, but just wondered if anyone else has had a faulty one?
Pickles.
Post #329213 8th May 2014 8:24am
schuee
Hi Pickles,
Not heard of this before though I'm sure someone will enlighten you, I would get it sorted out pretty sharpish as brake fluid is nasty stuff, and also mainly for your own safety and peace of mind.
Post #329220 8th May 2014 8:56am
munch90
where is the crack on the bottle?
Post #329221 8th May 2014 8:59am
clifflandy
United Kingdom 2007 Defender 90 Puma 2.4 HT Zambezi Silver
Saw similar issue on a '10 plate Puma but don't think it's a common fault Smile
Post #329281 8th May 2014 1:04pm
Pickles
There is a seam going down the middle of the front of the bottle,....it is in that area.
Pickles.
Post #329504 8th May 2014 10:20pm
