Home > Puma (Tdci) > Light Clutch Pedal After Fitting Of New Clutch |
hydraulics won't effect pressure now felt on pedal different from before it was done , even if they were changed ( unless cyl bore size changed which I've never heard of )
pressure is from the clutch pressure plate , some new ones do feel very light compared to old one does clutch seem to grip well when driving , no slipping etc |
5th May 2014 8:37pm |
schuee Member Since: 16 Jul 2012 Location: Lincolnshire Posts: 378 |
Hello Munch90,
No slipping clutch seems to grip well, and gearchange is normal, well for a Defender that is Only questioning as for some strange reason liked how it was before. but if the pressure plate is a different setup, I will have to get used to it, anyway thanks for sharing your knowledge mate, Cheers |
5th May 2014 9:03pm |
I wouldnt worry how light it is , just get used to it and be grateful
just keep eye on that's it gripping ok , don't dip clutch under load to check its ok , if it glazes or gets hot then they are never as good after |
5th May 2014 9:13pm |
