Home > Maintenance & Modifications > Frustrating noise !!
DavidBMB
I have a very frustrating noise that I cannot seem to locate. Initially we thought it was a wheel bearing as it sounds like a "wu wu wu wu..." That gets faster with speed. I took it to a garage and they had it in a rolling road and listened to each bearing in turn and thought all where ok. They thought it might be the tyres but although the are worn I can't see anything obvious. The all have worn on the inside edge.
The noise is more pronounced at 30 and 70mph and louder on a smoother road. I had all the diff and gearbox oil changed and nothing out of the ordinary there. There are no real vibrations on the steering wheel or gear stick so though this rules out drive shafts? The car has done 48k miles do not too high.
Any ideas?
Post #328561 5th May 2014 5:18pm
K9F
DavidBMB wrote:
it sounds like a "wu wu wu wu..." Any ideas?
Police car or ambulance would be my guess? Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #328568 5th May 2014 5:40pm
munch90
if it was mot rolling road ( brake test rollers ) then I don't ever think you would tell if wheel bearing had gone
rollers to noisy and slow
better to jack up ( with axle stand of course ) and spin by hand and listen or maybe feel roughness
if they a harsh pattern ( mud ) the knobbles wear odd , look like there worn on a slope , sort of angled , seems to happen more on inside or outside edge of tyre
that can make a noise bit like wheel bearing humming sound
could try swapping wheels round corner to corner , so osf or nsr etc so rotation is changed , no good doing it if there directional
Post #328569 5th May 2014 5:43pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Does the noise get better turning 1 way and worse the other?
Post #328631 5th May 2014 9:20pm
DavidBMB
Thanks for the ideas. Swapping the tyres around didn't make that much difference but directional so could only do front to back. The noise doesn't seem to get any worse turning one way or the other.
Post #328635 5th May 2014 9:51pm
Bobbles
United Kingdom 2013 Defender 90 Puma 2.2 HT Orkney Grey
Did you ever solve your frustrating noise problem? I have a noise on my 2013 90 that sounds pretty much identical to what you describe. Stealers have changed the transfer box under warranty - I think this was an expensive waste of time but they know what they are doing.... Anyway that didn't really make a difference and I have lost faith with them over this issue and a couple of others so I am reluctant to waste further time with them.
I think I will ask my indy to take a listen but if you can point me in the right direction, that may help!
Ta
Bobbles
Post #540387 15th Jun 2016 11:25am
Prop balancing, or UJ wear perhaps?
Post #540391 15th Jun 2016 11:35am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
That's the kind of noise my knobbly tyres make. TD5 Defender 90
Discovery 3 HSE
Post #540394 15th Jun 2016 12:03pm
Happyoldgit
Tyres would be my bet too. Steve.
http://forums.lr4x4.com
Post #540413 15th Jun 2016 1:14pm
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Swap it for the budgie that lives behind my dash! Cannot find it.
Post #540461 15th Jun 2016 3:55pm
Bobbles
Thanks for the suggestions - i am not sure that the tyres will be at fault. They are standard fit Contis - they look ok but i do have a spare set of Grabbers so I think i might try them to see what the effect is. The noise does sound more mechanical - bearings possibly - and is coming from the rear if that is of any relevance...
I too have the budgie behind the dash. He only chirps on cold days. I will be eliminating him soon but the other noises are currently more worrying to me (and my wallet)!
Bobbles
Post #540500 15th Jun 2016 5:41pm
familymad
Had this once and was UJ's starting to go. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #540525 15th Jun 2016 6:59pm
DavidBMB
Bobbles
Hi Bobbles
It was the standard tyres on mine. Like yours the noise sounded like it was coming from the rear although I think the acoustics in the car make it hard to place. After replacing all four tyres with new ones the noise went away. If you look closely at your tires, especially on the inside edge you may see some of the tread sections higher then others (sawtooth wear). This was the culprit! It sounded just like a wheel baring noise.
As for the squeak behind the dash. I had that and sorted it by greasing the moving parts in the small box where the clutch slave sits. Just infront of the bulkhead under the bonnet at the top driver side of the engine bay.
Hope this helps. Cheers.
Post #541065 17th Jun 2016 1:32pm
mk1collector
The budgie will be the plastic bonnet hinge inserts. Ray
My build thread
Post #541085 17th Jun 2016 4:27pm
Bobbles
DavidBMB many thanks - and also to everyone else. Seems I may have a busy weekend then.... although I think that Mrs bobbles has other ideas. If I have chance I will swap some wheels and see if that changes things. I will report my findings. Think the budgie might have to wait a while but he is quiet at the moment.
I really wonder why I keep buying land-rovers. There is always something that needs fettling or some tiresome rattle or squeak. I kid myself that it's a bit of character sadly lacking in other vehicles and one day I may come to my senses but I love my defender and still smile to myself when I drive off in the morning.... Or maybe it's a grimace Razz
Post #541133 17th Jun 2016 8:40pm
