Home > Maintenance & Modifications > Stuck inner wheel bearing removal |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 96 |
Cut it off with an angle grinder
4th May 2014 9:48pm |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
Might be able to get access to an angle grinder, although that's not a dead cert...was something I'd considered! 1998 110 300Tdi White Hard Top
4th May 2014 9:51pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Cheap 4 inch angle grinder from Tesco. Pov.spec,ftw. 2006, 110,TD5.
4th May 2014 10:28pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17374 |
A proper bearing separator would probably do the job best if you can get hold of one.
5th May 2014 6:23pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
You might not have enough edge to get a good grip on it. I needed to use an angle grinder too.
I made 2 cuts about 90 deg from each other not completely through as I did want to damage the stub. And then hammered the out of it till it came loose. It took some time but it worked. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
6th May 2014 8:42am |
Grey110 Member Since: 20 Jun 2012 Location: Delft Posts: 35 |
Did the bearing overheat and disintegrate? If yes then the stub axle and bearing will be fused together and you need some violence. If the bearing is still in one piece then try a better puller, it is a tight fit.
I removed mine with an angle grinder as well. Two cuts and then it falls off. I had no stub axle available so cleaned it up with the angle grinder and reassembled with a new bearing and seal. Replace as soon as possible, but you can drive this way. Or a cold chisel is less damaging to the stub. Martin Previous 2003 Defender 110 Hardtop TD5 2004 Defender 110 Station Wagon TD5 - Libyan Sand 2005 Discovery 3 - V8 - Black |
6th May 2014 2:57pm |
Cheers people. I managed to get it off. A lot of heat and hammering, I thought the stub would be pretty knackered after the effort, but it cleaned up pretty well, so all good now. 1998 110 300Tdi White Hard Top
7th May 2014 9:28pm |
