Home > Puma (Tdci) > Final check before fitting an intercooler |
Good morning all!
With the impending delivery of my new intercooler from BAS this week - sooo excited - I just wanted to check I am "install-ready". I copied this brief info from a thread ages ago (many thanks to the poster) but can't find it now: Remove fan cowling and grill. Loosen 2 bolts on bottom of AC radiator housing. Remove only right side 2 b"bolts" of the bonnet catch plate on the radiator side of fender by using a vice grip. (you will destroy these 2 bolts so make sure you have 2 spare bolts to replace these! I used normal bolts for future ease) OR use 2 nuts to lock then undo. Loosen 2 I C pipes and bolts. Pull old I C. Trim 2 plastic edges of radiator slightly. Pop new I C in and secure bolts and pipes. Are there any other tips or tricks I should be aware of? Does anyone know of a "how to" with pictures? Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th May 2014 7:19am |
have the air-de-gassed at a garage , don't just undo the pipes
4th May 2014 7:44am |
Regard - yes, I believe it was you - many thanks
Matt *Edit* do I really need to degas the aircon if going from above? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
I would, makes it easy to work on , air con pipes and rad (condenser) a bit fragile ,easy to crack a pipe , if you do crack a pipe its not nice to get a face full of gas
and get it re-gassed and bit of fresh oil ready for summer nobody really bothers but air-con should be re gassed every couple of years , so not really a waste of money |
4th May 2014 7:52am |
Good point - I will certainly consider it before banging around in there.
Is refilling the aircon expensive (at the dealer's, obviously). I don't remember ever having it done. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th May 2014 8:39am |
land rover will be more expensive , don't know how much where you live , but around here its 40-50 quid if you take it to normal garage
think land rover sent me a "special offer" some time ago and it was well over 100 quid |
4th May 2014 8:42am |
When fitting mine the airconditioning didn't have to be degassed at all, just undo the condensor and carefully fit the intercooler. Why spend/waste extra money if you don't have to?
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
4th May 2014 10:04am |
I bet there lots of people fitted without degassing , but I wouldn't , if you ever get a face full of gas and oil sprayed everywhere then some will then wish they de-gassed
also means condenser can be removed out of the way and save any damage to it pipes can crack quite easy sometimes on the welded joint where the pipe joins the end piece also like I said good time to get service done on air con and bit of fresh oil , funny how some people panick what oil to put in here there and everywhere do it along time before its due or needed then never touch the air con , if you get a pump break up and spread bits of metal round the system its a bl@@dy pain and it will never work as good without full strip down and pumps are EXPENSIVE Last edited by munch90 on 4th May 2014 11:46am. Edited 1 time in total |
4th May 2014 11:19am |
Mal - what do you mean undo the condensor? Tell someone you love them today because life is short.
4th May 2014 11:41am |
the condenser is the air con rad that's mounted in front of the intercooler ,so the intercooler is fitted between condenser and engine rad
you have to remove some or all of the mounting bolts that hold the frame that the condenser is fitted into the top bolts on the frame hold the bonnet slam latch panel the bottom bolts to the chassis |
4th May 2014 11:52am |
Aaah - that's what you call it. I thought there was another bit needed doing Tell someone you love them today because life is short.
4th May 2014 11:57am |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 |
Really no need to de-gas anything.
There is plenty space if you loosen the bottom 2 bolts holding the AC rad in place. First time around it took me 3 hours. Second one took me no more than a hour. |
4th May 2014 3:44pm |
Quick question - I'm trying to get the slam panel off and I'm not sure which way to rotate the studs/bolts. Are they studs, i.e. I should get them out anticlockwise towards the I C or bolts I should screw into the wing?
5th May 2014 3:44pm |
they studs anti clock and screw them out to ic
5th May 2014 3:46pm |
