![]() | Home > Td5 > fitting soft top |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Easy, 30 mins max to get the cab off, then soft top on, everything is there. Only issue will be seat belt mountings.
garethmorgan50 Member Since: 16 Jan 2014 Location: Herefordshire Posts: 94 ![]() ![]() |
I'm having a problem with getting the header rail fitted.. the clamps aren't long enough to go through the windscreen and the rail and yet they seem to be the only ones available (standard fit)... otherwise its easy.
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 ![]() ![]() |
Give yourself an afternoon to to it properly and neatly, as you havent done it before.
![]() from. ![]() Click image to enlarge to.. ![]() Click image to enlarge If you have any problems or any specific issues drop me a pm and ill give you my number, but you should be fine ![]() Last edited by SailingTom on 3rd May 2014 6:57pm. Edited 1 time in total |
I seem to remember I had a problem like this when I fitted one, it does fit, but it needs playing with, sorry but persevere!
Like Lee says they fit but take a bit of jiggling, get them all on loose before you tighten anything
Can anyone take some close up pictures of the corners and the clamps to check I'm doing it properly.. did anyone need to drill holes??
Is yours a clamp down earlier header rail or a push in td5/ puma one? I have the push in one so pics of mine wont help by the sounds of it Defender puma dormobile camper
An earlier rail.. with the round strip at the front.
Fullfat Member Since: 30 Apr 2014 Location: Lincolnshire. Posts: 271 ![]() ![]() |
Thanks all, going to choose one to buy, currently a truck cab but had a look at nene overland today and loved the soft top look. Going to speedliner the rear as well.
Fullfat.. have you looked at Line-x? really good..
Fulfat. Not wanting to put you off. but take it youve driven a soft top defender.
I dont have an issue with it and the extra practicality makes up for it with me but a lot hate them, its certainly noisy, Try one first if you havent ![]() |
Yes I know what you mean, no straight through exhaust for me !
Haven't research linex yet, looking for recommendations for an applicator |
Atlas coatings, staffordshire...
