![]() | Home > Wheels & Tyres > Insa Turbo Special Track Tyre Pressure Please |
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
Not sure what they are supposed to be but I run Special Tracks on my S2A and since I don't' do anything extreme requiring very low pressures or heavy loads requiring higher pressures, I find that 30 psi seems to be about right.
Super tyres and I am sure you know of their characteristics in the wet, plus the unique noise they make on tarmac. I wouldn't put anything else on the S2A now, though. ![]() Click image to enlarge HTH until someone comes along with a proper answer. 1970 Series 2A 88" |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20627 ![]() ![]() |
I run 32 front 38 rear, others run similar if slightly different pressures.
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Cheers guys I will try them at around 30psi first and see how they are
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
