Home > In Car Electronics > 110xs sw add 2nd row interior light |
Yes you can
Additionallly you could change the bulb for LED bulbs, I sourced them on Ebay... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite Last edited by VeeTee on 2nd May 2014 4:47pm. Edited 3 times in total |
2nd May 2014 4:44pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20477 |
If you use LED lighting then you can tap in to the original as the power consumption is MUCH lower. Using incandescent bulbs though is a no go.
Look in my gallery under interior lighting and you will see some ideas there. |
2nd May 2014 4:45pm |
ronwong Member Since: 28 Jun 2012 Location: Singapore Posts: 120 |
I bought the lamp housing/ switch. Its a on off and door mode. So I can just connect parallel by pulling 3 cables from the 3rd row?
The bulb is another thing, in fact I am happy enough with the original bulb |
2nd May 2014 4:47pm |
That's not true, Steve. Whilst LED's are very nice, the standard bulbs are still less than 1 amp each and adding a second is well within the capabilities of the wiring. People were doing this sort of mod long before LED's became common. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
2nd May 2014 5:18pm |
I pulled from the front. Just a cable about 1m for each, the 2nd row light does not dim in door mode with the first and 3rd row and also is much dimmer. Maybe it's bad wiring, I will try to do it again.
3rd May 2014 9:23am |
LRA I didn't know that, if the wiring can take it then all very well. All the same it's not designed to take more.
Or less for that matter but in my case I matched LED consumption pretty closely. |
3rd May 2014 10:02am |
