Home > Td5 > dmf fault? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6073 |
Mine does that tinkling thing.... damn annoying it is too!
1st May 2014 7:04pm |
kevinf Member Since: 12 Apr 2011 Location: sheffield Posts: 55 |
I'm not so much worried about the tinkling noise as i am the heavy knocking noise!, does this mean I'm taking the box out again .
diesel jim do you frequent the 4x4overlandtravel site by any chance cheers kevin |
2nd May 2014 10:07am |
Yeah that's me over there.... Good site too. As is the HUBB
2nd May 2014 10:17am |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
Sorry to sidetrack bu 4x4overlandtravel is great.
Seems quiet though. Just so much good info on there Defender 90 XS TD5 (03 Reg) |
2nd May 2014 8:47pm |
having spent the weekend away with the landrover club off-roading at newark the knocking noise seems to be getting worst
but nothing as failed yet,still thinking its the DMF so now the question is do i replace the dmf or fit a solid conversion (smf) i know the topic as been raised before but what are the negative issues of fitting a smf??? cheers kevin |
6th May 2014 10:19am |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Can I ask what symptoms your gearbox was showing and what milage it had done? I currently have a thread going in the maintenance and modifications section as I have gearbox woes. 2002 110 td5 |
7th May 2014 11:11am |
Hi jimb
The symptoms were a heavy rattling rumble whilst driving thru the gears apart from 4th gear ,also it was present in overrun! Initial diagnosis was a missing gear tooth on the lay shaft,but turned out to be very badly worn layshaft bearing,almost to the point of breaking up The mileage is 107000 Hope this helps Kevin |
7th May 2014 9:29pm |
Ellis01 Member Since: 16 Nov 2012 Location: Durham Posts: 14 |
Sadly as we do quite a lot of these, many clutches outlive the flywheels. Did you check for play?
14th May 2014 7:53pm |
update time
turns out it wasn't the dmf after all (yes it was checked for wear but i decided it was servicable) the heavy frightening knocking noise was caused by the x brake hand brake conversion (more specifically the britpart handbrake cable supplied free with the x brake when purchased from paddocks), so the moral of the story is allthough i saved £24 onthe cost of a cable it could have cost me a lot more if i had jumped the gun and took the gearbox back out! cheers kevin |
20th May 2014 10:25am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
My R380 mainshaft bearings gave out at 22,000 miles. Just out of warranty.
Got an Ashcroft recon exchange which is great. |
20th May 2014 10:39am |
