Home > Maintenance & Modifications > egr blanking kit
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
egr blanking kit
Hi I have just taken my 2001 td5 back after getting an egr blanking kit installed, On the short run home I noticed a distinct lack of pulling power over 50 miles an hour.
Is this normal and if so does the engine management unit need re mapping?
Regards Dave I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #327350 30th Apr 2014 7:44pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
The ECU shouldn't need any changes.
Maybe there is a leak on the exhaust manifold where blanked which would reduce boost?
Phil www.td5.org
Post #327353 30th Apr 2014 7:55pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Make sure you've blanked off the vacuum pipes correctly, if not it may not run correctly, just double check. Shouldn't need remapping to show an improvement.
Post #327393 30th Apr 2014 8:55pm
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
check all the fixings, after a good run they might of relaxed, especially the hose from the intercooler, that one creates a lack of power!
Post #327402 30th Apr 2014 9:13pm
DRW58
Thanks for the suggestions I'll have a look.
Regards DRW I built a garage for my Mini
Post #327436 1st May 2014 2:37am
