![]() | Home > Td5 > nanocom one PC software. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Glad you made it across to here
![]() Hope someone can help you. And welcome Andy |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
If you register on the Nanocom site you can download it
![]() http://nanocom.blackbox-solutions.com/index.php/forum |
That's how I did mine bought second hand, no problems at all.
dirtyninety Member Since: 30 Apr 2014 Location: Chesterfield Posts: 3 ![]() ![]() ![]() |
Currently trying to register to the nanocom forums, keep getting rejected because my nanocom ID is incorrect... I'm entering it perfectly, case sensitive and everything!
Glad I've registered over here Andy, there is a lot of good tech on these forums! |
I had the same issue but it turned out the Nano dip lays what I thought was a 0 (zero) it looked like an o.
Anyway emailed a photo of the serial to BBS and they sorted for me ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
I downloaded it all too, dead easy.
If you fling me your postal address I'll burn a disc off with the files. might take a day or two though as I've got a full few days at work. |
Should all be sorted now, thanks for the offer jim!
David at BBS has emailed me over the software and is adding my nanocom to their database as it doesn't show as existing! |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
I saw a Nanocom on eBay last week and wondered wether to have a bid, it was probably the same one!
In a nutshell, what exactly does the Nanocom allow you to do? I've had a look on the Nanocom website but without registering the info is limited. Is it diagnostics for problems or more for tuning? I used to have a tuning package that shared maps (which were all available free online), turned off sensors etc on my Triumph race bike (tuneECU). It was a useful piece of free software for diagnostics and tuning, is the Nanocom similar? I don't have any problems with my Td5 but love to have a fiddle and I'd like to know if it's worth investing first. |
The Nano one is pretty basic as a standalone unit. But is small and handy in the cubby for reading and clearing fault codes.
When connected to the PC it's a pretty useful bit of kit allowing to change/modify most of the ECU & 10AS settings You can also change the maps |
shyy Member Since: 18 Feb 2013 Location: TLV Posts: 8 ![]() ![]() |
HI ,
In this link you can find all the nanocom files you need for the nanaocom one including the drivers folder for your pc (windows drives) NanocomNew.exe -is the software for diagnostics https://www.dropbox.com/sh/ggnug68zu2x2rlk/d-kbwcGILx Shay 1999 Defender TD5 110 |
Guzzio Member Since: 09 Feb 2014 Location: Belgium Posts: 29 ![]() |
Does it runs on Windows 8.1? I don't get the Nanocom connected to my pc.
