![]() | Home > Maintenance & Modifications > Instructions for mobile storage system window guards |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Don't they just screw on?
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
Not sure, I have no instructions! I suppose the question is, do I need to remove the whole of the side trim to fit them or not?
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Presuming Internal ???
My MSS internals never came with instruction,, But yes,, the Trim has to come out Pic may help ?? ![]() Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Perfect, thanks mate
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 ![]() ![]() ![]() |
Hi, thinking about buying a set of these. Does the trim go back on without any cutting? Will also be needing the rear guards for the door and 2 smaller windows, assume they are similar fixing scenario. Martin |
Hi Martin
I did not need to cut the trims,same guards have been fitted to 3 110's now The side quarter window are a pita to fit mind Hope this pic helps ![]() Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
That's great, thanks.
Martin |
