Page 672 of 1377 <123 ... 671672673 ... 137513761377>
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Thanks G-mack
Barbel jim I had to be the driver don't think I could take Trish having to get that close to the tin tent Whistle Whistle
Plus don't think the caravan would like me leaning on the roof It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #326268 26th Apr 2014 6:08pm
sparkylee
Nice looking pair Stu Thumbs Up It's good to be back from the dark side
FFRR 4.2 vogue
Post #326270 26th Apr 2014 6:09pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Looking good stu Thumbs Up
Post #326297 26th Apr 2014 8:27pm
Romadog
Went off to my workshop to change the filter on my auto box. Had the parts for ages and just seen this video on youtube which gave me the nudge to do it.
&list=UUgoIeWV_UcrvqdXAiz3s8Vg
The problem was they didnt say anything about shearing the sump drain bolt with an odd ball thread different to everything you have in your shed ! Evil or Very Mad
A kind friend took me to a mates yard to rob one from a scrap unit. We returned only to find that the thread in the sump was damaged. As we couldnt find a tap that suited, it was back to the mates yard to remove the sump as well. Annoyingly this was rusty on the outside, unlike mine which was shiny clean. Never mind into the parts washer it went and onto the vehicle. Oil added and no leaks... Bow down
I didnt even get the chance to re align my steering wheel !!
If anyone can confirm the thread size of the drain plug it would be appreciated Thumbs Up
Post #326302 26th Apr 2014 8:48pm
shaggydog
Found some steel box section I had left over from a project and decided to make some seat rails to see if it actually makes any difference.
Measure, Cut, Clean
Paint
Fitted
First impressions? Seems more comfy, though not sold on the idea, not done a long enough journey yet.
Also flushed my radiator and changed coolant as my temp problem seems to have crept back in Banging Head
Post #326312 26th Apr 2014 9:43pm
shaggy - i did the same but added some plastic push in ends to take away the metal edges, they are about 10p each
Post #326338 27th Apr 2014 8:08am
shaggydog
bpman- There in the post on there way to me!
One thing it did bring home to me was how badly I need to change my seat cushions. So much yellow fluff!
Post #326388 27th Apr 2014 11:14am
ryanf
Did a quick tidying up of the front grille today. Will likely get this one replaced but did a quick spray to at least get the grey away for now.
When removing it, some of the plastic screw backings started to rotate in place and had to be held in place while unscrewing- took some creative maneuvering to get those out. Will want to change out all the mounting hardware when this gets replaced. Lots of 26 year old brittle plastic! Looks like I'll need to move the land rover badge up a notch back to the original placement Whistle
What it looked like before:
Back on after paint:
And from yesterday- enjoying the view during a quick drive around town Very Happy
Post #326398 27th Apr 2014 11:59am
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Swapped the start line of the Yorkshire 3 peaks race to the finish line using the roof rack as a platform
Post #326403 27th Apr 2014 12:22pm
a13x
Looks great. Can you show how and what brackets have been used to mount your foxwing? Struggling to get mine mounted without taking to get some custom mounts made.
Post #326416 27th Apr 2014 1:41pm
leeds
Alex, try some 1/4 x 2" mild steel plate. Two 9mm holes at 100 or 110mm centres (check back of Foxwing) and some 8mm hex headed bolts. Just sandwich the roof rack side rail between the Foxwing back plate and the 1/4" plate.
OK if you want to get more sophisticated get some flat bar the same thickness as the side rail to use as large washers.
Or get thicker plate and mill a grove the size of the side rail into it with the 9mm holes drilled in.
Brendan
Post #326419 27th Apr 2014 2:02pm
Blacktt600
Here you go:
Post #326421 27th Apr 2014 2:07pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Well yesterday decided to change the clutch. Took it out found oil in the bell housing and a wobbly gear shaft! Looks like ashcroft will get some business.
Post #326423 27th Apr 2014 2:12pm
Blacktt600
What rack do you have?
Post #326424 27th Apr 2014 2:12pm
a13x
Hannibal. Wanted to fit without using the side rails. Will investigate further.
Post #326433 27th Apr 2014 3:02pm
