Home > Td5 > Sorry another headlight query!!
charliebaja
United Kingdom 2002 Defender 110 Td5 CSW Zermatt Silver
So yes another headlight issue, so I shall make this as short and precise as possible.
The vehicle is a 2002 110 CSW TD5
The issue here is that when I switch the headlights on, the sidelights work but that's it. Full beam only works with the large stalk when you pull it towards yourself in flashing mode.
I have replaced the main switch but no luck with any headlights.
I have checked the fuses, all of which are ok, also checked the wiring which all seems fine.
I haven't checked the relays.
I have read all the other posts but still not sure what it could be. Not sure where all the relays are for this issue.
Your help would be greatly appreciated as I am off to Wales a week on Saturday an will be needing headlights.
Post #325540 23rd Apr 2014 8:14am
landy andy
Check wires and operation of main beam flasher stalk. That's what was the problem for Gareth R on here.
Andy
Post #325541 23rd Apr 2014 8:17am
Gareth
Yarp, new flasher/indicator switch assembly sorted the problem. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #325543 23rd Apr 2014 8:34am
charliebaja
Ordered a new indicator full beam stalk - hopefully this will sort the issue out. Further more i have checked to relays under the dash and they seem to be working ok.
I will keep you updated.
Post #325648 23rd Apr 2014 6:20pm
VeeTee
Netherlands
Indeed most probably faulty contacts in the indicator/headlight stalk. If you put in a new one, you should also do the headlight loom upgrade, otherwise it will happen again, sooner or later. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #325658 23rd Apr 2014 7:08pm
jimbob7
Is it upgraded bulbs that destroy (or help destroy) the switches,or does it happen wi regular bulbs?. Pov.spec,ftw. 2006, 110,TD5.
Post #325739 23rd Apr 2014 11:07pm
VeeTee
Netherlands
It happens with normal bulbs too. The cause is the bad design of the switch, copper contact in a piece of plastic. Because the current of all lights go through these contacts, they get hot and the plastic where they are seated melts. The contacts become loose and vo�la ...
With the replacement loom only a small current needed to switch the relays go through the switch. Cheers, Vincent
MySite
Post #325755 24th Apr 2014 6:59am
RockJaw
United States 2013 Defender 110 Puma 2.2 SW Santorini Black
Well that's exactly right. One of the oldest and well known issues with defenders for many years already has been the overloading of the headlamp 12V wiring, but this is easily managed, especially for the forewarned.
One excellent/essential mod to reduce the issue is to simply install LED headlamps right from the beginning. Much less current and less heat on the entire loom all round this way.
Before LEDs we would always take our brand new Defenders and rewire our headlights to separate relays without thinking twice about it. With LEDs this is not so important anymore. ****CENSORED****
Post #325756 24th Apr 2014 7:13am
charliebaja
Well guys thank you for the tips and help here, but just one other question:
Where would I find a new loom, as in which company is best - is there a part number i can use?
Post #325935 25th Apr 2014 5:32am
jimbob7
Not cheap but probably the best,Google will translate it,
https://shop.landreiziger.nl/lichtversterk...elaar.html
Or make yer own
http://www.defender2.net/forum/topic25376.html Pov.spec,ftw. 2006, 110,TD5.
Post #325968 25th Apr 2014 11:08am
Tazz
Presumably you have fixed your problem by now? What was the cause?
Post #333155 24th May 2014 7:50am
charliebaja
The cause was a faulty main beam switch. It looked all good, but it was faulty so replaced with a new one, which is all very easy to do, except a nag to take the steering wheel off and on.
Post #333843 26th May 2014 10:45pm
