Home > Technical > td5 fuel pipe
simon77
United Kingdom 1999 Defender 110 Td5 HT Alpine White
td5 fuel pipe
Hi all, this is my 1st post on this forum. Iwould like some advice on the hp fuel pipe from the pump to pressure reg, is it the same spec for defender and disco mine split near the fuel pump at the weekend do I need to replace the whole length ie is it pre made either end? The only ones I have found on ebay seem to be disco only?
Thanks
Simon.
Post #325594 23rd Apr 2014 12:40pm
mk1collector
I think that's the one that split on me on the way to France last year. You will need the full pipe and (last year) it was only about £15 from main dealers so probably best to order from them as it should be right first time.
Post #325647 23rd Apr 2014 5:18pm
simon77
Ok, thanks for the info.
Post #325654 23rd Apr 2014 5:49pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
If you want to "try before you buy" I have a full set of Disco ones sitting around doing nothing. It wasn't me!
Post #325719 23rd Apr 2014 9:23pm
simon77
Thank you very much for your offer if i get stuck I'll give you a shout!
Does anyone know the part no. This pipe ??
Post #326077 25th Apr 2014 8:29pm
Need to know if you have a 90, 110 or 130 to start with.
Then what engine you have (10P, 15/16P) as the ends are moulded differently to suit the different fuel cooler.
Post #326595 28th Apr 2014 7:06am
simon77
Hi, it's a 1999 110 hard top sorry but not sure of engine number will check when I get home it is the original engine though.
Post #326642 28th Apr 2014 12:07pm
1999 should be 10P
Post #326678 28th Apr 2014 2:03pm
simon77
Thanks jim, so now we know that does anyone know the part no. ??
Thanks
Simon
Post #326688 28th Apr 2014 2:31pm
Should be WJP500090 (was previously WJP107910)
Post #326730 28th Apr 2014 4:40pm
simon77
Cheers thanks for the help !
Post #326737 28th Apr 2014 5:02pm
simon77
Post #326738 28th Apr 2014 5:02pm
