Home > Puma (Tdci) > Diesel fuel contamination and wrecked fuel pump |
Bossman Member Since: 06 Feb 2008 Location: Inverness Posts: 1 |
Sounds like cobblers to me! These vehicles are tested exhaustively in extreme conditions-are you suggesting that normal road use in rainy conditions will cause a serious water contamination problem? I think not! I have been in the motor trade for many years and know these vehicles (and many others) intimately. If your problem is genuinely due to water contamination, it is more likely to be due to contaminated fuel from either elderly, corroded fuel storage tanks or from drums used for refuelling. I am happy to be proved wrong on this one but I think that in the fullness of time, a more logical root cause will be found. It annoys me to hear people condemning these excellent vehicles and their skilled designers, in a bid to cover for their own poor "fuel hygiene" or just plain ignorance and incompetence!
I look forward to any reply to this post! |
6th Feb 2008 11:02pm |
dullbird Member Since: 25 Aug 2007 Location: sydney Posts: 87 |
yeh well mate we have the same problem and facing 10,000 bill to fix it and the car has only been on the road for 6months.....so did the same fuel driver deliver his load to oz as well!! strangley enough and maybe a coincidance but the month it all began was the heighst rain full seen in that month in something like 70years!!!!!!!!!!! so i think before you go attacking other members about there poor FUEL HYGIENE.......maybe take it on board and keep and open mind YOU KNOW REHAB IS FOR QUITTERS!!!! |
22nd Jul 2008 1:42pm |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 |
Have a look at:
http://www.defender2.net/forum/topic396.html Tim |
22nd Jul 2008 2:33pm |
foz.in.oz Member Since: 31 Jul 2008 Location: Gladstone, QLD Posts: 64 |
Just spent the evning around a friend of mine who has a new Puma engined Defender. He's been having problems with stuttering and the MIL coming on.
Drained the fuel filter into a clean coffee jar and it doesn't look good. Half of the contents was dirty water. So she's off to the dealer tomorrow for the inquest. He uses the same servo that I fill up at and my TD5 shows no symptoms of water in the fuel at all. He has driven the car in wet conditions on road (we've had some pretty wet days lately) and hasn't been near so much as a puddle off road. Looks like another one for 'faulty tank breather'. I just hope we have caught it in time without stuffing any up. It's a real shame that the new Defender is suffering this fault as it is otherwise a very nice vehicle. Land Rovers are an addiction. Toyotas are for quitters. WWW.CQLROC.ORG |
31st Jul 2008 11:32am |
sorry to here that, tell them chin up land rover know about it and its now a fix.........can i ask you foz if you can keep me updated with the problem and HOW they fix it!!
thanks mate YOU KNOW REHAB IS FOR QUITTERS!!!! |
31st Jul 2008 12:04pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
As mentioned a known problem with extensive posts on here and lro - where i have hosted the pdfs Mike
31st Jul 2008 4:16pm |
Will do, Dullbird. Land Rovers are an addiction. Toyotas are for quitters.
WWW.CQLROC.ORG |
31st Jul 2008 8:59pm |
Chaser Member Since: 03 Aug 2008 Location: brisbane Posts: 9 |
Was a bit worryed about the water problem with the fuel tank breather so I have moved mine
Click image to enlarge Click image to enlarge so when i do this it should be ok Click image to enlarge cheers chaser if it moves shoot it, if it dosn't push it. |
3rd Aug 2008 7:05am |
whatch out for fuel vapours in the cab Mike
3rd Aug 2008 3:13pm |
Update on my friends Defender Dullbird,
Dealer removed the tank and washed it out. same with pump and fuel lines. Replaced a switch on the fuel rail? and repositioned the breather behind the tail lamp cover. All done under waranty with no charge. collected and delivered the vehicle too (350kms round trip). Looks like we caught it before it destroyed the injectors although my friend is keeping a very close eye on things. Land Rovers are an addiction. Toyotas are for quitters. WWW.CQLROC.ORG |
18th Aug 2008 1:37am |
B19DEF Member Since: 05 Apr 2008 Location: Oop North Posts: 5 |
This is a known problem with land rover, there is even a TSB on it!! the fuel breather is incorrectly positioned, and draws in water and mud etc. this then wrecks the high pressure fuel pump.
Fault rectified by fitting new tank, breather, filter, HP pump, common fuel rail and finally, new diesel!! |
19th Aug 2008 9:41pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Is the fuel pump before the filter outside the tank?
I found quite a bit of silt in the bottom of the external fuel filter. Puma 110 - gone Series III 1973 - going strong |
20th Aug 2008 5:32am |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
The Pump is forward of the filter and attached to the engine. The filter is designed to filter the fuel and seperate any water before it gets to the pump and the common rail injection system. The problem is with the breather location and the ingestion of large quantities of water...more than the filter can cope with and more than prescribed service intervals anticipated. The water and muck therefore finds it's way into a high precision system that doesn't tolerate it. Attached are some pdfs from the GTR site that describe the system: http://www.defender2.co.uk/gallery/albums/...ration.pdf http://www.defender2.co.uk/gallery/albums/...in-off.pdf http://www.defender2.co.uk/gallery/albums/...ration.pdf Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
20th Aug 2008 10:38am |
How about the rest of the manuals Puma 110 - gone
21st Aug 2008 5:00am |
