Home > Maintenance & Modifications > Td5 Automatic. More gears required?
Autoairride
United Kingdom 2002 Defender 90 Td5 HT Auto Chawton White
Anyone know of an electronic auto box conversion for the td5 other than the zf4hp22? I am convinced it needs more gears, at least five. Banging Head Banging Head Banging Head
Post #324578 18th Apr 2014 9:22pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
I have a Td5 90 with the zfhp24, but originally we were going for the 22. The crux of the matter is to make sure you drive the vehicle and set the electronic gear changes to suit how you wish the vehicle to drive. We use the Compushift controller to do the set up, and it took quite a bit of tweeking to get it right, but it now drives very well. No need for any more gears.
(It is possible to put a an electronic zf22 from a TD5 Discovery straight into a Defender, but it will not be set up correctly for thr Defender td5 ecu which is why you need a separate means of adjustment to get the gear changes matching torque patterns and driver preferences)
I believe a 6 speed auto is available (eg GM import from the US) and this is pretty much needed if it's a Puma auto conversion, but really with a good setting up/fettling with a controller on a td5 you should be fine with the 4 speed ZF. We are working our way around Australia in ours at the moment and despite the weight it is carrying, there is enough pull to get us where we want to be without constantly changing up/down.
We have an upgraded intercooler but no re-map, so pretty standard engine performance but as I say, it works just fine with the set up we have. Thumbs Up
There are others who no doubt have other opinions!! Wink Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #324699 19th Apr 2014 3:06pm
Autoairride
Yep, I know all about tweaking the compushift.... The problem I have is that the settings are very restricted when it comes to varying loads on the vehicle. I can set it to work well when the vehicle is unladen but as soon as the trailer goes on the back, the settings are miles out because you are pressing the throttle harder to achieve momentum. I even changed the torque converter for one with a lower stall speed, but a heavy throttle position just shoots the revs past what the converter can handle. That's why I was searching for an auto box with more gears, to try and take the revs off the converter.
Don't even get me started about the fuel consumption.....
Lets have those opinions!!
Thanks for the reply and enjoy your travels.. Thumbs Up
Post #324763 19th Apr 2014 9:00pm
H3nry
Pam,
Do you have info on the 6-speed?
Post #324815 20th Apr 2014 8:24am
Pam W
No, just know you can get them, as read here and there about them being fitted to Defenders. Do a google search or contact Ashcrofts.
Although we are not towing the all up weight of my Defender is around 3 tons in current expedition setup - roll cage, roof tent, water, extra fuel, winch, hi-lift, tools, spares, camp kitchen gear, LPG bottle, clothes, ARB 47l fridge etc. As I say it does fine on the 4 speed.
We originally set it up as my commuter, shortish mixed urban/rural runs but when we started adding the extra weight we re-set it for that. Without the weight it runs quite happily on the same setting anyway. I would suggest trying to set it up for your worst case scenario, as it should then be ready for towing whenever. We got a bit of help at first from Patrick at Maddison 4x4 as he was the first UK specialist to work with the ZF and Compushift, direct with the US. We have 2 Defenders on Compushift now - mine plus Dave's 100" challenger motor which is 5.7 LS1 with a matched US autobox - also a 4 speed. Our blog - http://landytravels.com/
Post #324858 20th Apr 2014 11:57am
T1G UP
yep agreed, more gears are required for todays traffic and for better mpg. ive just got a vw transporter with the 7 spped dsg auto.....this is whats required in a defender.
the box is the box from the ford ranger auto. there also found in GM car in the states. its a version of the ZF box in the D3 etc
the ford ranger has the 2.2 transit / defender engine fitted they also fit the 3.2 auto Whistle
this is a great set up. there are a few controllers on the market as well as compushift
BUT for what it costs may be cheaper to buy a ranger!
Post #324862 20th Apr 2014 12:15pm
Autoairride
Thats what I'm talking about! If the four speed was ok for today's standards then everyone would still be using them. I have come to realise everyday use for work and towing is taking its toll on me and the fuel consumption! It's driving me mad! Banging Head
The landy earns its keep ok and I would love to find a more current and modern transmission. Anyone know how to fit this seven speed into a defender td5?! Laughing
Post #324983 20th Apr 2014 10:17pm
Fatboy Slim
Wales
Hi all, first post here for a long time (but I do lurk a bit Whistle ) I have a Td5 auto with the ZF 4HP, must say that I fitted one of ashcrofts heavy duty converters in my D2 and that made it 100% better (same box of course). The trouble is, I cannot justify the cost of another one for the defender and I feel that the defender would be far better as a manual for what I do, so a manual retrofit is in progress.........The Td5 is a revvy beast in auto form no matter what you do sadly, it seems to suit some more than others, I find it great for long runs but hopeless up and down the mountains. Its up and down the box like nothing on earth.
Post #325448 22nd Apr 2014 8:48pm
Fatboy Slim
Wales
Ps mine is the 'mechanical mod' 4HP so has a kickdown cable and no electrics, no electrical bits here Whistle
Post #325450 22nd Apr 2014 8:50pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
It sounds to me like you have more of an issue with final gearing rather than gears. Extra gears on an auto don't stop it changing gear, quite the opposite. If you find that it's kicking down and hunting between 3rd, 4th, 4th lock up you'll probably find that a lower final output will give better fuel consumption and improve driving.
The TD5 should be able to cope quite happily with a 4 speed unless it's over geared or has an issue that means it's down on power.
What tyre size are you running ?
What transfer box ratio ?
What intercooler ?
Has it got an aftermarket tune on the TD5 ? http://www.yorkshireoffroadclub.net/
Post #325523 23rd Apr 2014 12:34am
Autoairride
Davew, thanks for your post.
Tyres: 265/75/16 BGF AT
Transfer box 1:4
Alive/Sercks full size intercooler
Alive remap with larger turbo (not vnt)
So it's not power I'm short of....I think? I kept the 1:4 box when I did the conversion, as Patrick at Maddison 4x4 said the 1:2 would be to tall for towing, I'm glad I did or it would be worse! I have resorted to using TCC lock up in third @40mph as forward progress was hopeless when towing if unlocked. This way of setting the box has highlighted how far apart 3rd and 4th ratios are, hence my search for more gears.
Post #325727 23rd Apr 2014 10:36pm
ashtrans
Site Sponsor
Hi,
Do you know if Patrick fitted the stock converter or the larger HD one we supply,
I don't think you need more gears, the TD5 discos don't have these problems on the ZF, either the stock converter is slipping excessively which they do if the engine is tuned or the Compushift needs adjusting,
Do you have the CS1 or CS2 Compushift ?
Dave Dave
Post #325754 24th Apr 2014 6:51am
Autoairride
Hi Ashstrans,
H/Duty converter, with CS1. Was thinking about using CS2, to make use of the two different shift setting feature. One for towing, one without. Also the TCC can be manually overridden, right? Is it worth the upgrade?
I also have a spare GKN overdrive, what about adding that into the mix!?
Post #325904 24th Apr 2014 9:45pm
Fatboy Slim
Wales
Hi Dave, I spoke to you earlier this week regarding my auto box (Stu that works for Cat) I think this is the issue with mine to be honest, I would certainly say it has been remapped and seems to have the higher ratio transfer box.
The box itself shifts beautifully, just seems a bit revvy when in converter drive 3rd speed. I am still going to remove it as the vehicle would be far more use to me in manual form. Pity really, but it's the correct decision to make for the use of the vehicle and I'm sure someone will make good use of the auto conversion once removed!
Post #325905 24th Apr 2014 9:46pm
