Home > Maintenance & Modifications > Sealey Aluminium Jacks |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Pretty sure Sealey sell the generic alloy trolley jacks that everyone sells, can't remember seeing reviews for the low entry jack but from all accounts the other alloy jacks in the range are very good.You "slammed" yer Defender or summut??Pics please ! Pov.spec,ftw. 2006, 110,TD5.
19th Apr 2014 11:39am |
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 |
There are actually a lot of different brands on the market! I noticed Sealey is on of the few who has a opitons regarding load and single or double cylinder. I was looking at the Snap On as well. Not keen getting an Aldi one....
m |
19th Apr 2014 11:55am |
Ragerover Member Since: 26 Dec 2013 Location: In a land far far away Posts: 145 |
Snap on is obviously the way to go.... If your using it all the time
Sealyham make decent quality But Costco have a deal at the moment 2t alloy low entry jack with quality wheels etc for under £100 Your better off with a higher rated jack Check they've got good quality wheels and the bigger the base the more stable Check out the lift height too so you can lift from the diff on the Landy Neat trick if you don't know it is to put some rubber pipe insulation on handle so when handle is vertical it doesn't scratch paint |
19th Apr 2014 4:57pm |
Thanks for that. I used my mates 1300kg all the time working on my 110 and never found it underrated. Will have a look at the Costco one. m
20th Apr 2014 4:59am |
