Home > Technical > Over reving when changeling gear |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
If you sit stationary and rev up without having it in gear and then take your foot off the accelerator does the same thing happen? Defender 90 XS TD5 (03 Reg)
18th Apr 2014 9:57am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5700 |
Tdci's do that! Is that what you have?
Andy |
18th Apr 2014 3:57pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2754 |
Isn't this the 'check your brake light fuse' thing that confuses the **** out of everyone? Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
18th Apr 2014 11:06pm |
2dae Member Since: 21 Sep 2013 Location: Maudsland Posts: 27 |
I've checked a few things
1 it does rev normally when in neutral or in gear with clutch in 2 all fuses seem to be good but ill double check in the mornin 3 my Landy guys told me maybe the fuel sensor on the clutch ( it's near the clutch fluid filler ) so I changed it for a new one , fitted It rebled clutch , but still the same , seems to be more noticeable in 1st 2nd and 3 rd gear when you press in clutch and take your foot off accelerator it gild rev high for about 2-3 second before decelarating |
19th Apr 2014 5:13am |
Also. To mention
I've got a 2008 110 defender 2.4 motor Click image to enlarge |
19th Apr 2014 5:19am |
sounds like the anti-stall, mine does the same (2007 2.4)
19th Apr 2014 5:47am |
Hey bp man
Where is the anti stall located Have you replaced yours ??? What is the antistall used for i thought 1st gear only Mine is noticable in 1st 2nd 3rd |
19th Apr 2014 10:16am |
http://www.defender2.net/forum/topic28113....brake+fuse Cheers, David
19th Apr 2014 12:17pm |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 189 |
Forgive my stupidity but... I have the same reving problem but my brake lights work?? Does it still apply regarding the blown fuse?
19th Apr 2014 1:27pm |
anti-stall is part of the standard ecu map, i guess it really depends on how pronounced the revs are when you change gear. i can run up a hill in 1st or 2nd and the engine keeps the power on without any pressure on the accelerator, you can feel the engine "take control" - that's the anti-stall. hth |
20th Apr 2014 6:31am |
Big George Member Since: 06 May 2014 Location: Westhoughton Posts: 3 |
My Defender been doing this sometime now, just seems worst lately, been advised to unplug 'over rev sensor' located under bonnet next to brake servo? Can't seem to locate. Can anyone advise please.
[/b] |
6th May 2014 9:11pm |
